Libredrive version v6
Re: Libredrive version v6
Post by SamuriHL » Sat Aug 15, 2020 2:59 am
Especially on triple layer discs. I turn speed control off for triple layer UHD. It just isn't reliable enough on those discs. They are notoriously irritating to begin with, so, trying to read them faster is not especially helpful. I sometimes slow them down if they give me too much trouble.
Mr_Orange
Post by Mr_Orange » Sat Aug 15, 2020 3:02 am
Is the speed control setting coming to the GUI soon?
allomere
Post by allomere » Sat Aug 15, 2020 3:03 am
MartyMcNuts wrote:
Yes, it is more likely to happen.
Interesting. Anyone else experienced this?
Post by SamuriHL » Sat Aug 15, 2020 3:07 am
Mr_Orange wrote: Sat Aug 15, 2020 3:02 am Is the speed control setting coming to the GUI soon?
Unsure. Mike intentionally didn't put it in the GUI because I think he wants more testing of the feature. It works but as has been discussed, it can put more wear and tear on the drive if you overdo it. I've got 3 drives (2 ns60 1.00 and one asus bw-16d1ht flashed to ns60 1.00) and I have 0=99;u3=0 set on all 3 of them. That seems to work well for me, but, your mileage may vary. For now, I don't think this feature is quite mainstreamed yet.
Mr_Orange
Post by Mr_Orange » Sat Aug 15, 2020 3:12 am
SamuriHL wrote: Sat Aug 15, 2020 3:07 am
Thank you. The first time I read the instructions I didn't fully understand how to edit the settings. A further reading has fixed that so I'm happy to give it a try.
Also good to know that there are no drive speed commands sent to the drive if the settings are blank/missing which means that my drive is currently doing its own thing and presumably not being overworked.
midnighwatcher
Post by midnighwatcher » Mon Aug 24, 2020 2:40 am
allomere wrote: Sat Aug 15, 2020 3:03 am
I had a BD explode into a million pieces. Took an hour to clean the drive. It's not as reliable as before, not sure if it was the optical grenade or the full throttle.
jonghotti
Post by jonghotti » Mon Aug 24, 2020 3:43 pm
You’re fond of referencing that story.
donut
Post by donut » Tue Aug 25, 2020 3:30 am
Mike,
I have an old BD-RE WH14NS40/MT1939 drive that I noticed LibreDrive was enabled with the recent update. I want to thank you for your effort to bring this capability to an older drive like this.
Thanks for your continued efforts!
Octoross2
Post by Octoross2 » Fri Jan 14, 2022 5:49 am
Hello everyone, I'm new to this and I'm not exactly sure which steps to take.
Here are my product information. How do I enable Libredrive or how do I update my firmware to do so? I can't seem to find a firmware anywhere for this specific drive...
Product: BD-RE BH40N
Revision: GAT2
Serial number: K9HD8982752
Firmware date: 2115-03-27 11:22
Bus encryption flags: 1F
Drive platform: MT1939
Thank you!!!
Post by Billycar11 » Fri Jan 14, 2022 6:03 am
Octoross2 wrote: Fri Jan 14, 2022 5:49 am Hello everyone, I'm new to this and I'm not exactly sure which steps to take.
Revision: GAT2
Thank you!!!
Don't bother almost nothing for you to gain yours can do UHD
Octoross2
Post by Octoross2 » Fri Jan 14, 2022 2:09 pm
That's my problem, I can't read my UHD disc at all... :S
Post by Billycar11 » Fri Jan 14, 2022 2:11 pm
Octoross2 wrote: Fri Jan 14, 2022 2:09 pm That's my problem, I can't read my UHD disc at all... :S
Yeah sorry man that drive never read will UHD even if it's flashed
Pick one from the guide below and flash it
or from a seller preflashed
Octoross2
Post by Octoross2 » Fri Jan 14, 2022 4:59 pm
Will do! Thanks
