evaluation copy alert!!!???
miltk
Post by miltk » Fri Jan 14, 2022 12:11 am
when i try to rip a bluray disc i get an "evaluation period" alert saying my makemkv "trial" will end in 14days and do i want to continue.
is this a glitch in the program when it rips blu ray? it never happens with dvd's
thx
Re: evaluation copy alert!!!???
Post by Woodstock » Fri Jan 14, 2022 12:23 am
If you're on a permanent key, it shouldn't happen.
Beta key allows Bluray operations for 30 days after you start using BD features. DVD features do not have that time limit.
The BD timer is reset when you input the beta key, even if it's the same beta key you're already using. It just has to be a currently-valid beta key.
miltk
Post by miltk » Fri Jan 14, 2022 7:16 am
Woodstock wrote: Fri Jan 14, 2022 12:23 am If you're on a permanent key, it shouldn't happen.
i don't have a key and i never have, been using the program for a few yrs and this alert only started popping up with blurays
Post by Woodstock » Fri Jan 14, 2022 2:13 pm
You do have a key - the Beta key is in the install for the program.
Have you read the Key FAQ in the General section yet?
