can i buy pioneer bdr212ubk for 4k uhd playback with powerdvd 21 ultra? my specs:
msi z490 tomahawk
32gb ram 3866mhz
intel i9 10900k wih sgx support
new drive
Re: new drive
You could and it should work but I wouldn't rely on it you are not using a graphics card at all?hardcore_gamer29 wrote: Wed Jan 12, 2022 2:49 pm can i buy pioneer bdr212ubk for 4k uhd playback with powerdvd 21 ultra? my specs:
msi z490 tomahawk
32gb ram 3866mhz
hardcore_gamer29
Re: new drive
i am using asus gtx 1650 ddr6Billycar11 wrote: Wed Jan 12, 2022 10:10 pmYou could and it should work but I wouldn't rely on it you are not using a graphics card at all?hardcore_gamer29 wrote: Wed Jan 12, 2022 2:49 pm can i buy pioneer bdr212ubk for 4k uhd playback with powerdvd 21 ultra? my specs:
msi z490 tomahawk
32gb ram 3866mhz
Re: new drive
then nohardcore_gamer29 wrote: Thu Jan 13, 2022 9:01 ami am using asus gtx 1650 ddr6Billycar11 wrote: Wed Jan 12, 2022 10:10 pmYou could and it should work but I wouldn't rely on it you are not using a graphics card at all?hardcore_gamer29 wrote: Wed Jan 12, 2022 2:49 pm can i buy pioneer bdr212ubk for 4k uhd playback with powerdvd 21 ultra? my specs:
msi z490 tomahawk
32gb ram 3866mhz
that wont work
go for unofficial playback only lg and asus drives can do that for now see list in guide below.
pioneer may be supported soon but not yet
hardcore_gamer29
Re: new drive
thanks and is there any difference in performance between LG 16ns60 and ASUS BW-16D1HTBillycar11 wrote: Thu Jan 13, 2022 10:00 amthen nohardcore_gamer29 wrote: Thu Jan 13, 2022 9:01 ami am using asus gtx 1650 ddr6Billycar11 wrote: Wed Jan 12, 2022 10:10 pm
that wont work
Re: new drive
no difference not even a difference between a WH14NS40 and those once flashed if you get a desktop drive get the cheapest one a WH14NS40hardcore_gamer29 wrote: Thu Jan 13, 2022 11:39 am thanks and is there any difference in performance between LG 16ns60 and ASUS BW-16D1HT
they are all the same drive
i personally only recommend the slim drives BU40N and BP60 or similar i have had way to much bad luck with the full size ones
hardcore_gamer29
Re: new drive
is lg wh16ns60 supported with makemkv?Billycar11 wrote: Thu Jan 13, 2022 11:58 amno difference not even a difference between a WH14NS40 and those once flashed if you get a desktop drive get the cheapest one a WH14NS40hardcore_gamer29 wrote: Thu Jan 13, 2022 11:39 am thanks and is there any difference in performance between LG 16ns60 and ASUS BW-16D1HT
Re: new drive
Yeahhardcore_gamer29 wrote: Thu Jan 13, 2022 4:37 pmis lg wh16ns60 supported with makemkv?Billycar11 wrote: Thu Jan 13, 2022 11:58 amno difference not even a difference between a WH14NS40 and those once flashed if you get a desktop drive get the cheapest one a WH14NS40hardcore_gamer29 wrote: Thu Jan 13, 2022 11:39 am thanks and is there any difference in performance between LG 16ns60 and ASUS BW-16D1HT
