Failure to save
theorracle
Failure to save
Post by theorracle » Tue Mar 01, 2011 1:20 am
While converting my copy of Willy Wonka, I find this happens, for no apparent reason:
MakeMKV v1.6.5 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/jorr/MakeMKV_log.txt
Optical drive "DVD+R-DL HL-DT-ST DVDRW GA32N KC12" opened in OS access mode.
It's highly recommended to install DASPI kernel extension to improve performance.
Optical drive "BD-ROM HL-DT-ST BDDVDRW CH08LS10 1.00" opened in OS access mode.
Evaluation version, 25 day(s) out of 30 remaining
Title #00016.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00017.mpls was added as title #0
Title #00018.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00020.mpls was added as title #1
File 00029.mpls was added as title #2
Title #00003.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00030.m2ts was added as title #3
File 00039.m2ts was added as title #4
File 00040.m2ts was added as title #5
File 00041.m2ts was added as title #6
File 00042.m2ts was added as title #7
Title #00043.m2ts has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00044.m2ts has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00045.m2ts was added as title #8
Title #00047.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00056.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Users/jorr/Movies/Willy_Wonka_and_the_Chocolate_Factory
Error 'Posix error - Input/output error' occurred while reading '/BDMV/STREAM/00030.m2ts' at offset '11509825536'
DEBUG: Code 0 at #;T"M"((KWQ(BN@0+&DY:29394298
DEBUG: Code 0 at Jv=}O/f18Nlqc%&i6<I=:121261681
DEBUG: Code 0 at #;T"M"((KWQ(BN@0+&DY:29394183
DEBUG: Code 5620032 at #;T"M"((KWQ(BN@0+&DY:29393309
Failed to save title 1 to file /Users/jorr/Movies/Willy_Wonka_and_the_Chocolate_Factory/title01.mkv
0 titles saved, 1 failed
Permissions are fine. Disk space is plenty fine. No idea why it won't save.
I appreciate any help that can be offered.
Re: Failure to save
Post by mike admin » Wed Mar 02, 2011 10:14 am
This is likely a physically damaged disc. To confirm, please install DASPI 1.2 (from this forum, not from MakeMKV package! ) and try again - with daspi you'll see fully decoded error messages.
