Dune 2021 Bluray which title?
gana2k1@gmail.com
Hi
I just purchased the Dune (2021) Blu-ray US Version from Amazon. Did not get an error but makemkv shows 3 titles with 36.8GB as follows
1. Dune_t04.mkv shows 18 chapters with segment count 1, 00800.mpls, Duration 2:35:26
2. Dune_t05.mkv, 18 chapters, Segment Count 1, 00801.mpls, Duration 2:35:26
3. Dune_t08, (doesnt show any chapter count), Segment Count 1, 01218.m2ts, Duration 2:35:26.
Does anyone know which title to extract?
Here is debug log
Debug log started at Wed Jan 12 02:31:23 2022 , written by MakeMKV v1.16.5 win(x64-release)
001005:0000 MakeMKV v1.16.5 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\../MakeMKV_log.txt
003338:0000 Downloading latest SDF to C:\Users\../.MakeMKV ...
DEBUG: Code 3 at kx/mIn.tna?p(7TlCFJMk\o%:29395310
SDF v07f: HL-DT-ST_BD-RE__WH16NS40_1.02_211512111459_SIK9QG6D8391
001011:0000 Using LibreDrive mode (v06.2 id=76A0C3CD522E)
DEBUG: Code 2147483648 at W*;d/f1]i)<B5EJP:121264625
DISCID=D445956EE6F33D673A31F132C905B4EE2D81A4ED
003025:0000 Title #00054.mpls has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00055.mpls was added as title #0
003025:0000 Title #00053.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01309.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01314.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01310.mpls has length of 110 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00120.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00120.mpls(1) was added as title #1
003025:0000 Title #00140.mpls has length of 110 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00201.mpls was added as title #2
003307:0000 File 00207.mpls was added as title #3
003307:0000 File 00800.mpls was added as title #4
003307:0000 File 00801.mpls was added as title #5
003307:0000 File 00301.mpls was added as title #6
003307:0000 File 00307.mpls was added as title #7
003025:0000 Title #01065.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01067.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01068.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01069.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01070.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01071.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01073.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01074.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01075.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01076.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01086.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01066.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01063.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01007.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01206.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 01218.m2ts was added as title #8
003307:0000 File 01227.m2ts was added as title #9
003025:0000 Title #01231.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01236.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01233.m2ts has length of 110 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01234.m2ts has length of 110 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01235.m2ts has length of 110 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 01223.m2ts was added as title #10
003307:0000 File 01224.m2ts was added as title #11
003307:0000 File 01225.m2ts was added as title #12
003307:0000 File 01237.m2ts was added as title #13
003025:0000 Title #01238.m2ts has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 01239.m2ts was added as title #14
003307:0000 File 01240.m2ts was added as title #15
003025:0000 Title #01241.m2ts has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 01242.m2ts was added as title #16
003307:0000 File 01243.m2ts was added as title #17
003307:0000 File 01244.m2ts was added as title #18
003307:0000 File 01245.m2ts was added as title #19
003307:0000 File 01246.m2ts was added as title #20
003307:0000 File 01247.m2ts was added as title #21
003307:0000 File 01248.m2ts was added as title #22
003307:0000 File 01249.m2ts was added as title #23
003307:0000 File 01250.m2ts was added as title #24
003307:0000 File 01251.m2ts was added as title #25
Here is debug log
Re: Dune 2021 Bluray which title?
I've ripped all three and will watch them to make sure they are correct. I'll try and report back in a bit.
Most likely playlist 00800.gana2k1@gmail.com wrote: Wed Jan 12, 2022 2:50 am Hi
Here is debug log
Well in terms of sub tracks and languages tracks, t08 has the most (17 sub tracks and 12 audio), then t04 has like 15 subs and 11 audio, and then t05 has only english and japanese I think.
So far it seems you are correct.
gana2k1@gmail.com
Thanks everyone for the quick responses.
0800 - here I come.
0800 - here I come.
I tried all 3 and everyone 'skips' a little every few seconds. Audio seems fine but the video does not.
Seems like a playback device or bandwidth issue and not a playlist issueRezyn wrote: Thu Jan 13, 2022 3:19 am I tried all 3 and everyone 'skips' a little every few seconds. Audio seems fine but the video does not.
What are you playing on and how
As others have pointed out, 800 is the playlist you want. This is the correct playlist for every Warner Brothers disc I’ve ever remuxed.
gana2k1@gmail.com
Yes I can confirm too that 800 is the right one. Good to know about Warner Bros and 800 connection. Will keep that in mind.
Let me try 800 again. Highly doubt playback or bandwidth is the issue, all my other movies been working fine.
However, we watch primarily on roku's. But I test them all on my PC first, dune I tested on my PC, which is hardwired into my router. Current 720 down / 20 up Mbps
gana2k1@gmail.com
I use Kodi to watch on my firetv and normally for fast action sequences or rapid movements, these high def movies do lag/stutter slightly and in my case it has always been bandwidth/device(firetv)/buffering issues. On my PC through VLC, same scenes always plays perfectly fine. I am not playing through the network but directly from the file stored on my hard disk in the computerRezyn wrote: Fri Jan 14, 2022 1:35 am Let me try 800 again. Highly doubt playback or bandwidth is the issue, all my other movies been working fine.
TaliesinWI
I'm not aware of any Fire hardware that's rated past 20 mbps for h.264 content. (Frame rate/etc is irrelevant if you're shoving more bits at the hardware accelerator than it can handle.) Since Blu Ray is rated for max 40 mpbs, you might get peaks here and there that exceed that.gana2k1@gmail.com wrote: Fri Jan 14, 2022 2:24 pmI use Kodi to watch on my firetv and normally for fast action sequences or rapid movements, these high def movies do lag/stutter slightly and in my case it has always been bandwidth/device(firetv)/buffering issues. On my PC through VLC, same scenes always plays perfectly fine. I am not playing through the network but directly from the file stored on my hard disk in the computerRezyn wrote: Fri Jan 14, 2022 1:35 am Let me try 800 again. Highly doubt playback or bandwidth is the issue, all my other movies been working fine.
