Black Panther - unable to rip disc
cycled-valance
#1 Post by cycled-valance » Tue Jan 11, 2022 11:01 pm
I am running into errors, below, when I try to copy a a 4K UDH disc of Black Panther using MakeMKV 1.16.5 on a Windows 11 machine. Any help to resolve this would be appreciated. I have tried cleaning the disk multiple times, restarting the software and my machine, and nothing seems to work.
I see the following info in the sidebar:
Product: BD-RE BU40N
Revision: 1.00
Serial number: MO9L5A84816
Firmware date: 2116-12-20 15:28
Highest AACS version: 61
Firmware version: 1.00
Disc Information
Label: BLACK_PANTHER
Timestamp: 2018-03-26 16:33:34
Protection: AACS2.0/C v61
Data capacity: 57.7 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
I get the following (shortened) error message on the console when I try to copy the disc:
Evaluation version, 26 day(s) out of 30 remaining
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at v/79B2&2&>5Y>W)/}:213130766
DEBUG: Code 0 at #:'-Gd^FRDq~O@:2Z=:29395195
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at #:'-Gd^FRDq~O@:2Z=:29396552
DEBUG: Code 4 at #:'-Gd^FRDq~O@:2Z=:29394275
Downloading latest HK to ***/.MakeMKV ...
Saved AACS dump file as ***/.MakeMKV/MKB20_v61_MARVEL'S_BLACK_PANTHER_CC0B.tgz
DEBUG: Code 0 at S#u\au|JPy)q5}Kp:29396092
DEBUG: Code 0 at S#u\au|JPy)q5}Kp:29395172
Re: Black Panther - unable to rip disc
#2 Post by Billycar11 » Wed Jan 12, 2022 12:18 am
cycled-valance wrote: Tue Jan 11, 2022 11:01 pm Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT'
You should never be seeing those messages on UHD disc that means your drive lost power and libre drive is only half activated you will need to full unplug the drive and try again you may need a high power USB hub make sure your plugging both cables in
cycled-valance
#3 Post by cycled-valance » Wed Jan 12, 2022 6:12 am
That does it, thanks!
