Jaws 4K UHD with Pioneer BDR-XD07UHD
kbf100
Hello
Newcomer to this forum... I am attempting to rip one of my 4K Ultra HD discs (Jaws) using MakeMKV and I am receiving errors when opening the disc with MakeMKV. I attached the log. Is this drive (Pioneer BDR-XD07UHD) incompatible for ripping 4K UHD with this encryption? If so, I will want to return the drive.
THANK YOU!
Brian
Do I need to email Mike the .tgz file?
THANK YOU!
Brian
- Disc MakeMKV.PNG (4.05 KiB) Viewed 8167 times
- Jaws UHD MakeMKV.txt
- (61.32 KiB) Downloaded 297 times
Re: Jaws 4K UHD with Pioneer BDR-XD07UHD
Yes, your drive is not "UHD-Friendly", it is "UHD Official". Pioneer drives do not currently have available a "rip-friendly" firmware.
kbf100
Oh that's not good! Do you think it will be possible in the future?
Thanks for your help!
Brian
Brian
The software's author thinks it may be. In fact, the main screen (prior to opening a disk) have "LibreDrive status", which says he hopes to support it at some time in the future. Those of us who have variations on that drive have been waiting over a year since we submitted firmware samples.
The good news is that Pioneer drives seem to be better at WRITING disks than the UHD-Friendly drives.
It's possible it will be soonkbf100 wrote: Mon Jan 10, 2022 2:17 pm Oh that's not good! Do you think it will be possible in the future?
Brian
What is your firmware version?kbf100 wrote: Mon Jan 10, 2022 2:17 pm Oh that's not good! Do you think it will be possible in the future?
Brian
Mine is 1.01
kbf100
Thanks folks for the info. I *think* the firmware is 1.03 ? It says 1.03 in that bitmap I attached, but I would have to check. How do you verify firmware version?
Thanks again!
Brian
Thanks again!
Brian
kbf100
I found this ... From MakeMKV when opening Pioneer BDR-XD07UHD.
This may show needed info.
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XD07U
Revision: 1.03
Serial number: AFDL008724UC
Firmware date: 2020-08-20
Bus encryption flags: 13
Highest AACS version: 76
Status: Might be supported in future, keep fingers crossed
Drive platform: Pioneer RS8D31
Firmware version: ID05
Disc Information
Label: JAWS
Timestamp: 2020-03-31 14:07:37
Protection: AACS2.0/C v72
Data capacity: 93.22 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
OS device name: E:
Revision: 1.03
Disc Information
Label: JAWS
Number of layers: 3
Ok thanks for info so they definitely have been updated the firmware the developer got my firmware from.1.01 hopefully it also works on 1.03kbf100 wrote: Mon Jan 10, 2022 5:51 pm I found this ... From MakeMKV when opening Pioneer BDR-XD07UHD.
OS device name: E:
Revision: 1.03
Disc Information
Label: JAWS
Number of layers: 3
