Jaws 4K UHD with Pioneer BDR-XD07UHD
kbf100
Post by kbf100 » Mon Jan 10, 2022 1:18 pm
Hello
Newcomer to this forum... I am attempting to rip one of my 4K Ultra HD discs (Jaws) using MakeMKV and I am receiving errors when opening the disc with MakeMKV. I attached the log. Is this drive (Pioneer BDR-XD07UHD) incompatible for ripping 4K UHD with this encryption? If so, I will want to return the drive.
THANK YOU!
Brian
Do I need to email Mike the .tgz file?
Re: Jaws 4K UHD with Pioneer BDR-XD07UHD
Post by Woodstock » Mon Jan 10, 2022 2:04 pm
Yes, your drive is not "UHD-Friendly", it is "UHD Official". Pioneer drives do not currently have available a "rip-friendly" firmware.
kbf100
Post by kbf100 » Mon Jan 10, 2022 2:17 pm
Oh that's not good! Do you think it will be possible in the future?
Thanks for your help!
Brian
Post by Woodstock » Mon Jan 10, 2022 2:45 pm
The software's author thinks it may be. In fact, the main screen (prior to opening a disk) have "LibreDrive status", which says he hopes to support it at some time in the future. Those of us who have variations on that drive have been waiting over a year since we submitted firmware samples.
The good news is that Pioneer drives seem to be better at WRITING disks than the UHD-Friendly drives.
Post by Billycar11 » Mon Jan 10, 2022 2:45 pm
kbf100 wrote: Mon Jan 10, 2022 2:17 pm Oh that's not good! Do you think it will be possible in the future?
Brian
It's possible it will be soon
Post by Billycar11 » Mon Jan 10, 2022 2:48 pm
Brian
What is your firmware version?
Mine is 1.01
kbf100
Post by kbf100 » Mon Jan 10, 2022 5:45 pm
Thanks folks for the info. I *think* the firmware is 1.03 ? It says 1.03 in that bitmap I attached, but I would have to check. How do you verify firmware version?
Thanks again!
Brian
kbf100
Post by kbf100 » Mon Jan 10, 2022 5:51 pm
I found this ... From MakeMKV when opening Pioneer BDR-XD07UHD.
This may show needed info.
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XD07U
Revision: 1.03
Serial number: AFDL008724UC
Firmware date: 2020-08-20
Bus encryption flags: 13
Highest AACS version: 76
Status: Might be supported in future, keep fingers crossed
Drive platform: Pioneer RS8D31
Firmware version: ID05
Disc Information
Label: JAWS
Timestamp: 2020-03-31 14:07:37
Protection: AACS2.0/C v72
Data capacity: 93.22 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Post by Billycar11 » Tue Jan 11, 2022 12:32 am
kbf100 wrote: Mon Jan 10, 2022 5:51 pm I found this ... From MakeMKV when opening Pioneer BDR-XD07UHD.
OS device name: E:
Revision: 1.03
Disc Information
Label: JAWS
Number of layers: 3
Ok thanks for info so they definitely have been updated the firmware the developer got my firmware from.1.01 hopefully it also works on 1.03
