Dolby Vision MKV to MP4
HEMAN
#1 Post by HEMAN » Sat Jan 08, 2022 8:27 am
Hello I need some help. I have an MKV file that I can play directly on LG CX via usb but it has green blue tint. I know this is because tv cannot play DV from MKV. Audio is ATMOS and it works fine. I need to convert this file into a MP4 DV so that it will play properly on CX. I tired using DVDFAB but the ripper cannot recognize the MKV file.
Here is the media info
General
Unique ID : 27709276606451203734841161321554075792 (0x14D89CD06DB5962FD8530B84369F6090)
Complete name : G:\2021.DV.2160p.WEB.H265-SLOT.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 13.2 GiB
Duration : 2 h 4 min
Overall bit rate : 15.2 Mb/s
Encoded date : UTC 2022-01-04 06:52:44
Writing application : mkvmerge v63.0.0 ('Everything') 64-bit
Writing library : libebml v1.4.2 + libmatroska v1.6.4
Video
Format : HEVC
Format profile : Main 10@L5@High
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 14.4 Mb/s
Width : 3 840 pixels
Height : 1 592 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Variable
Frame rate : 23.949 FPS
Original frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.099
Stream size : 12.5 GiB (95%)
Default : Yes
Forced : No
Audio
Format : E-AC-3
Format/Info : Enhanced Audio Coding 3
Format profile : E-AC-3+Atmos / E-AC-3
Format settings, Endianness : Big
Codec ID : A_EAC3
Duration : 2 h 3 min
Bit rate mode : Constant
Bit rate : 768 kb/s
Channel(s) : 15 objects / 6 channels
Channel positions : 15 objects / Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 187.500 FPS (256 SPF)
Compression mode : Lossy
Stream size : 681 MiB (5%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 2 h 2 min
Bit rate : 36 b/s
Count of elements : 1202
Stream size : 32.7 KiB (0%)
Title : Simplified
Default : No
Forced : No
Text #2
Format : UTF-8
Duration : 1 h 58 min
Bit rate : 38 b/s
Count of elements : 1218
Stream size : 33.9 KiB (0%)
Language : German
Default : No
Forced : No
Text #3
Format : UTF-8
Bit rate : 39 b/s
Count of elements : 1186
Stream size : 34.4 KiB (0%)
Title : British
Language : English
Default : No
Forced : No
Text #4
Format : UTF-8
Bit rate : 39 b/s
Language : English
Default : No
Forced : No
Text #5
Format : UTF-8
Bit rate : 36 b/s
Count of elements : 1196
Stream size : 32.9 KiB (0%)
Title : Latin American
Language : Spanish
Default : No
Forced : No
Text #6
Format : UTF-8
Bit rate : 34 b/s
Count of elements : 1123
Stream size : 30.9 KiB (0%)
Title : European
Language : French
Default : No
Forced : No
Text #7
Format : UTF-8
Bit rate : 39 b/s
Count of elements : 1183
Stream size : 35.1 KiB (0%)
Language : Italian
Default : No
Forced : No
Text #8
Format : UTF-8
Bit rate : 38 b/s
Count of elements : 1219
Stream size : 34.9 KiB (0%)
Language : Korean
Default : No
Forced : No
Text #9
Format : UTF-8
Bit rate : 37 b/s
Count of elements : 1149
Stream size : 33.3 KiB (0%)
Title : Brazilian
Language : Portuguese
Default : No
Forced : No
Text #10
Format : UTF-8
Bit rate : 64 b/s
Count of elements : 1209
Stream size : 57.7 KiB (0%)
Language : Russian
Default : No
Forced : No
Text #11
Format : UTF-8
Bit rate : 63 b/s
Count of elements : 1217
Stream size : 56.9 KiB (0%)
Language : Ukrainian
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:08:01.940 : en:Chapter 02
00:14:49.806 : en:Chapter 03
00:21:00.844 : en:Chapter 04
00:28:09.230 : en:Chapter 05
00:35:44.602 : en:Chapter 06
00:42:12.699 : en:Chapter 07
00:49:54.703 : en:Chapter 08
00:56:34.102 : en:Chapter 09
01:03:55.710 : en:Chapter 10
01:10:29.229 : en:Chapter 11
01:18:20.784 : en:Chapter 12
01:24:49.297 : en:Chapter 13
01:31:55.348 : en:Chapter 14
01:40:09.217 : en:Chapter 15
01:50:39.222 : en:Chapter 16
hogfan
Re: Dolby Vision MKV to MP4
#2 Post by hogfan » Sat Jan 08, 2022 9:24 pm
It sounds like you have a Dolby Vision Profile 5 MKV.
You are going to run into two issues here: 1.) MP4 container doesn't support chapters (not a huge issue, but one to be aware of), 2.) MP4 Container does not support HD audio tracks (i.e. Dolby TrueHD)
Try this:
Install the following if you don't already have them:
1.) MKVToolNix
2.) gMKVExtractGUI
3.) FFMPEG
4.) MP4Muxer
- Use gMKVExtractGUI to extract all of the streams/tracks from your Dolby Vision Profile 5 MKV.
- Use ffmpeg to convert your Dolby TrueHD audio track into Dolby Digital (AC3) or Dolby Digital + (E-AC3). You will lose ATMOS and will be limited to 5.1 surround as ffmpeg conversion only supports up to 6 channels.
- Use MP4Muxer to remux all of the streams/tracks into a new MP4 container.
Play resulting MP4 back on your LG TV.
