A Failure with this Foreign Title BR Disc
Seeker47
#1 Post by Seeker47 » Fri Jan 07, 2022 9:30 pm
Just f.y.i. --
In Order of Disappearance
Original title: Kraftidioten | 2014 |
https://www.imdb.com/title/tt2675914/
(another source listed this as a 2016 title ?)
Here is what the MakeMKV job log showed:
DEBUG: Code 48 at +j,$qy}{6LI[t,':zp\x:29394758
The source file '/BDMV/STREAM/00002.m2ts' is corrupt or invalid at offset 10485430272, attempting to work around
< SNIP, for redundancy >
DEBUG: Code 64 at +j,$qy}{6LI[t,':zp\x:29394758
DEBUG: Code 179 at +j,$qy}{6LI[t,':zp\x:213133250
DEBUG: Code 0 at O{]l*x<upg.5#Kt)+A?Z:213131157
DEBUG: Code 0 at O{]l*x<upg.5#Kt)+A?Z:213131272
DEBUG: Code 5119842 at O{]l*x<upg.5#Kt)+A?Z:121261773
DEBUG: Code 0 at b'k_Gz0NVSfy&}LieHw>A:213129984
DEBUG: Code 0 at _Y+8iB|^MtysP|GFt:}V/:213137068
DEBUG: Code 3 at 3B#\%:BlUEu3k2A;:213132537
Hash check failed for file 00002.m2ts at offset 10491783168, file is corrupt.
Hash check failed for file 00002.m2ts at offset 10495125504, file is corrupt.
Hash check failed for file 00002.m2ts at offset 10499844096, file is corrupt.
Too many hash check errors in file 00002.m2ts.
Failed to save title 0 to file D:/Video/In Order Of Disappearance/In Order Of Disappearance_t00.mkv
Encountered 5 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
8 titles saved, 1 failed
I did read that link, which concludes with: "Getting this error usually means a failing Blu-ray drive." But there is no evidence for that presently, based on working with other BR discs. Incidentally, all of the other files, such as 002 above, did in fact render successfully.
