Any Way to Flash Asus BC-12D2HT?
papillon121
Post by papillon121 »
Hi!
is there actually any way to Flash this drive?
Asus BC-12D2HT
Re: Any Way to Flash Asus BC-12D2HT?
Of course. What is your issue?
papillon121
Coopervid wrote:
Fri Jan 07, 2022 7:35 pm
hi, thank you for your answer, please take a look at the screenshot of this thread at the end, can you help me?
viewtopic.php?f=16&t=22896&p=116967#p116967
How is your drive attached? USB? If yes, then the adapter is not supporting flashing. If attached by SATA don't use additional ports but use a port provided by the motherboard chipset. Usually they have different colors.
And you don't need to flash the boot loader...
