Re: SDFtool Flasher
i downloaded the updated sdf tool flasher and it gave me an error when trying to open it (its from 2020 the first one in this thread)...is this normal or is there another update somewhere? its for lg wh16ns40. it seems to have gotten more difficult since i flashed my last drive of that make a few years ago.
Re: SDFtool Flasher
What is the error?Jman5150 wrote: ↑Thu Jan 06, 2022 10:13 ami downloaded the updated sdf tool flasher and it gave me an error when trying to open it (its from 2020 the first one in this thread)...is this normal or is there another update somewhere? its for lg wh16ns40. it seems to have gotten more difficult since i flashed my last drive of that make a few years ago.
Also, there are 2 versions of the flasher available. Both links are in the first post.
Re: SDFtool Flasher
Thanks for the info. I didn't really know that this drive is special regarding UHDs. I will try to remember. And I always recommended BU40N if anybody was asking for a slim drive. You know that I'm more active over in the RF forum for that software.MartyMcNuts wrote: ↑Wed Jan 05, 2022 10:27 pm@Coopervid, Nah, he's only on BP50NB40 1.03-MK, which isn't UHD capable.
@1337_Nerd, Did you follow the steps exactly? If so and step 3 is the issue, can you please try this for step 3.
3. Flash firmware BP60NB10_1.00_MK_HBD. (If you don't already have the hybrid firmware, here is the link: download/file.php?id=2143
If that doesn't work, try the below:
3. Check the box to include the boot loader and flash firmware BP60NB10 1.00-MK.
Let us know how you go and I'll edit the steps.
Re: SDFtool Flasher
The flasher I used from a few years ago....It kept saying fail when I tried to flash 1.02, or 1.00 it still says it has the original firmware. there was another flasher (the updated one on this thread on the first page) (i forget what its called will look it up and post) and it gave me an error...looked as if it was already flashed or something like that ( it was allowing me to clear it but it had an x with a warning like it could cause somethign bad) it wasnt flashed. I saw there error in here somewhere will try to find it again.
Basically the problem is the firmware wont budge from the orginal 1.05. its like something is locking it in place. so im assuming im getting outdated stuff to flash it on. will check out the follow up and get back with how it went.
any other advise in the mean time appreciated...is there a way to post pics here to show warnings or such?
MartyMcNuts wrote: ↑Thu Jan 06, 2022 11:20 pmWhat is the error?Jman5150 wrote: ↑Thu Jan 06, 2022 10:13 ami downloaded the updated sdf tool flasher and it gave me an error when trying to open it (its from 2020 the first one in this thread)...is this normal or is there another update somewhere? its for lg wh16ns40. it seems to have gotten more difficult since i flashed my last drive of that make a few years ago.
Re: SDFtool Flasher
Ok, a new WH16NS40 with 1.05 firmware can only be flashed using the SDFtool Flasher, due to 1.05 being an encrypted firmware. The newest version of the flasher shoud show you a Green tick for MT1959 drive platform and a green tick to having encrypted firmware.Jman5150 wrote: ↑Fri Jan 07, 2022 12:41 amThe flasher I used from a few years ago....It kept saying fail when I tried to flash 1.02, or 1.00 it still says it has the original firmware. there was another flasher (the updated one on this thread on the first page) (i forget what its called will look it up and post) and it gave me an error...looked as if it was already flashed or something like that ( it was allowing me to clear it but it had an x with a warning like it could cause somethign bad) it wasnt flashed. I saw there error in here somewhere will try to find it again.
Now, I'm not sure what firmware you are trying to flash but the recommended firmware for that drive is WH16NS60 1.02-MK (in the "old" folder of the MK firmwre pack). The drive can be flashed to this firmware directly.
Re: SDFtool Flasher
oh so is that flasher in this thread too? or elsewhere? is the green tick all in the software once its up and running? I have the 1.02 but not the 1.02mk (not sure what mk means). i found a download earlier called (i forget) something like the everything you need bundle or something....would that one have all of what I need in it?
thank you so much...good to know i dont need to return it and that theres options out there. i was going to get an ASUS but in the reviews there were 2021 reviews saying it was an easy flash and here I am a couple days later....lol.
Re: SDFtool Flasher
This is called the "SDFtool Flasher" thread....Jman5150 wrote: ↑Fri Jan 07, 2022 2:23 amoh so is that flasher in this thread too? or elsewhere? is the green tick all in the software once its up and running? I have the 1.02 but not the 1.02mk (not sure what mk means). i found a download earlier called (i forget) something like the everything you need bundle or something....would that one have all of what I need in it?
Yeah, that all you need pack from Billy should contain all the common firmwares or you can get the flasher and firmware pack from the first post of this thread.
MK = MakeMKV firmware (firmware modified by the MakeMKV developer to enable LibreDrive and UHD ripping). The firmware pack(s) you download should all contain MK firmware. The firmware's original names have a long group of digits towards the end, so it is simply easier to just call them MK.
The ASUS is a rebadged LG anyway and the flash process is the same. The only difference is the ASUS doesn't contain encrypted firmware.
Re: SDFtool Flasher
the flasher window is tiny and squished ....it wont let me resize...is that odd...i hope so kinda stuck...too small to read whats what.
Re: SDFtool Flasher
What monitor are you using?
Re: SDFtool Flasher
macbook pro laptop, 2015 (windows with parellels )
i do have access in this building to normal office monitors but it would take a bit of work since its not mine if that is of importance. also my other windows size fine.
right before the flasher shows up it gives me this warning...
Unhandle exception has occured in your application. if you click continue the app will ignore the error and attempt to continue, if you click quit the app will close.object refernce not set to sn instance of an object."
then theres a very long window underneath witha bunch of stuff starting with exception text then a bunch of lines including stdflasher then system.windowa.forms.form.oncreat.....and the lines repeat for awhile till it gets to a bunch of text. i have photos but not sure how to upload if even possible.
Re: SDFtool Flasher
It's not really designed for VM etc. Best to use a windows PC or use the command line.Jman5150 wrote: ↑Fri Jan 07, 2022 6:10 ammacbook pro laptop, 2015 (windows with parellels )
Re: SDFtool Flasher
yeah do boot camp not parellels none of the new versions pass though the optical drive enough for flashing anyway even when it is set to pass through.
Re: SDFtool Flasher
hi, can i flash my Asus BC-12D2HT with that tool?
Re: SDFtool Flasher
ill try it out and see what happens. havnt tried boot camp before. I assume that has something to do with the encryption part? i was able to flash my other drives with my current setup...the older flasher works fine...just doesnt disarm the decryption.
(or thats what I assume papillon121 )\
______
______
MartyMcNuts wrote: ↑Fri Jan 07, 2022 6:28 amIt's not really designed for VM etc. Best to use a windows PC or use the command line.Jman5150 wrote: ↑Fri Jan 07, 2022 6:10 ammacbook pro laptop, 2015 (windows with parellels )
Re: SDFtool Flasher
ill try it out and see what happens. havnt tried boot camp before. I assume that has something to do with the encryption part that vm has issues?
just curious why is it smooshing the window of the flasher (assuming you know or its easy to explain). never seen it before...changed resolutions and didnt change anything.
ill load up bootcamp and install windows.
as far as the command line comment...a bit confused. I was just going to use the apps window. is command line worth trying in my vm setup?
command line...? you mean like in the type commands section? so the windows part doesnt work? or command lines better? what would I type or do you have a thread or link on it. thats a new way for me.
to papillon121 )\
thanks for the post.... in response i use mine for the simpler flashes tooo....i think the encyrption is what makes this a messy one and needs different hardware.
to papillon121 )\
