4K UHD HDR turn off ?
Are all 4K UHD in HDR ? Is it possible to get a non-HDR version such as the blu ray version, but in 4K UHD quality of course.
Re: 4K UHD HDR turn off ?
I don't think so. I believe the whole point is 4k resolution with high dynamic range.seleki7669 wrote: ↑Thu Jan 06, 2022 2:57 amAre all 4K UHD in HDR ? Is it possible to get a non-HDR version such as the blu ray version, but in 4K UHD quality of course.
AHHH I SEE. Also how come whenever I use the K-Lite Codec Pack's own MPC player to play ripped 4K UHD files, theres a high-pitched sound emitting from the computer ?MartyMcNuts wrote: ↑Thu Jan 06, 2022 3:22 amI don't think so. I believe the whole point is 4k resolution with high dynamic range.seleki7669 wrote: ↑Thu Jan 06, 2022 2:57 amAre all 4K UHD in HDR ? Is it possible to get a non-HDR version such as the blu ray version, but in 4K UHD quality of course.
coil wine what are your specs?seleki7669 wrote: ↑Thu Jan 06, 2022 3:37 am
coil wine usually only happen under high load so maybe your gpu does not support h.265 and its doing software decoding on the cpu
ASUS Z390PBillycar11 wrote: ↑Thu Jan 06, 2022 4:16 amcoil wine what are your specs?seleki7669 wrote: ↑Thu Jan 06, 2022 3:37 am
i7-9700K
16 GB RAM, I do not have a separate videos card currently, old one broke.
that cpus igpu has h.265 decoding wouldn't think that is much of a load to make it coil whine but its possible i guess.seleki7669 wrote: ↑Thu Jan 06, 2022 4:33 am
ASUS Z390P
i7-9700K
On the long run, is that coil whine detrimental to the CPU ? Will it cause problems ?Billycar11 wrote: ↑Thu Jan 06, 2022 5:06 amthat cpus igpu has h.265 decoding wouldn't think that is much of a load to make it coil whine but its possible i guess.seleki7669 wrote: ↑Thu Jan 06, 2022 4:33 am
ASUS Z390P
i7-9700K
not really just normal operationseleki7669 wrote: ↑Fri Jan 07, 2022 3:16 am
