4K UHD HDR turn off ?
seleki7669
Post by seleki7669 »
Are all 4K UHD in HDR ? Is it possible to get a non-HDR version such as the blu ray version, but in 4K UHD quality of course.
Re: 4K UHD HDR turn off ?
seleki7669 wrote:
Thu Jan 06, 2022 2:57 am
I don't think so. I believe the whole point is 4k resolution with high dynamic range.
seleki7669
MartyMcNuts wrote:
Thu Jan 06, 2022 3:22 am
AHHH I SEE. Also how come whenever I use the K-Lite Codec Pack's own MPC player to play ripped 4K UHD files, theres a high-pitched sound emitting from the computer ?
seleki7669 wrote:
Thu Jan 06, 2022 3:37 am
coil wine what are your specs?
coil wine usually only happen under high load so maybe your gpu does not support h.265 and its doing software decoding on the cpu
seleki7669
Billycar11 wrote:
Thu Jan 06, 2022 4:16 am
ASUS Z390P
i7-9700K
16 GB RAM, I do not have a separate videos card currently, old one broke.
seleki7669 wrote:
Thu Jan 06, 2022 4:33 am
ASUS Z390P
i7-9700K
that cpus igpu has h.265 decoding wouldn't think that is much of a load to make it coil whine but its possible i guess.
seleki7669
Billycar11 wrote:
Thu Jan 06, 2022 5:06 am
ASUS Z390P
i7-9700K
On the long run, is that coil whine detrimental to the CPU ? Will it cause problems ?
seleki7669 wrote:
Fri Jan 07, 2022 3:16 am
not really just normal operation
