I got it from amazon. Under what reason do I return or exchange it ? Do I have to revert it back to original firmware ?Billycar11 wrote: Fri Dec 31, 2021 2:51 pmTry a different UHD moviezarc987 wrote: Fri Dec 31, 2021 2:46 pm
I cleaned the disc, even used a 2nd copy of it, the same error still exists. Its always towards the end, the last few mins it messes up.
If the same thing happens I would return or exchange the drive
Question on Flashing
Re: Question on Flashing
Defectivezarc987 wrote: Fri Dec 31, 2021 3:29 pm
did you try a different UHD movie yet?
I tried a brand new and different UHD movie. Now its saying "The source file '/BDMV/STREAM/00278.m2ts' is corrupt or invalid". The disc itself is spotless. Just what is going on ?Billycar11 wrote: Fri Dec 31, 2021 10:12 pmDefectivezarc987 wrote: Fri Dec 31, 2021 3:29 pm
Yeah if its on multiple disc your new drive is defective return it and get a BU40N
Im on a budget. What budget ones you recommend ?Billycar11 wrote: Tue Jan 04, 2022 12:24 am Yeah if its on multiple disc your new drive is defective return it and get a BU40N
The BU40N
BP50
Bp60
Or any other clones of those they can be gotten for around $80-$90.
I don't recommend any of the 5.25 drives from LG or Asus they are the same.
BP50
Bp60
Is it possible that I reset the firmware back to its original and re-flash it ?Billycar11 wrote: Tue Jan 04, 2022 12:28 am The BU40N
BP50
Bp60
You could try but no need to go back to original. Just reflash NS60 1.02-MK and see if that helps.zarc987 wrote: Tue Jan 04, 2022 4:18 amIs it possible that I reset the firmware back to its original and re-flash it ?Billycar11 wrote: Tue Jan 04, 2022 12:28 am The BU40N
BP50
Bp60
May I ask, what about this one?MartyMcNuts wrote: Tue Jan 04, 2022 4:22 amYou could try but no need to go back to original. Just reflash NS60 1.02-MK and see if that helps.zarc987 wrote: Tue Jan 04, 2022 4:18 amIs it possible that I reset the firmware back to its original and re-flash it ?Billycar11 wrote: Tue Jan 04, 2022 12:28 am The BU40N
BP50
Bp60
HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010
you can try it but it likely wont fix anythingzarc987 wrote: Tue Jan 04, 2022 4:32 am
IF you were to recommend a LG or ASUS one, what would you say is a good one ?Billycar11 wrote: Tue Jan 04, 2022 12:28 am The BU40N
BP50
Bp60
They are basically all the same. The ASUS is a rebadged LG anyway. Just go with the cheapest one.zarc987 wrote: Thu Jan 06, 2022 1:50 amIF you were to recommend a LG or ASUS one, what would you say is a good one ?Billycar11 wrote: Tue Jan 04, 2022 12:28 am The BU40N
BP50
Bp60
