Question on Flashing
zarc987
Re: Question on Flashing
#16 Post by zarc987 » Fri Dec 31, 2021 3:29 pm
Billycar11 wrote: Fri Dec 31, 2021 2:51 pm
zarc987 wrote: Fri Dec 31, 2021 2:46 pm
I cleaned the disc, even used a 2nd copy of it, the same error still exists. Its always towards the end, the last few mins it messes up.
Try a different UHD movie
If the same thing happens I would return or exchange the drive
I got it from amazon. Under what reason do I return or exchange it ? Do I have to revert it back to original firmware ?
#17 Post by Billycar11 » Fri Dec 31, 2021 10:12 pm
zarc987 wrote: Fri Dec 31, 2021 3:29 pm
Defective
did you try a different UHD movie yet?
zarc987
#18 Post by zarc987 » Mon Jan 03, 2022 8:53 pm
Billycar11 wrote: Fri Dec 31, 2021 10:12 pm
Defective
I tried a brand new and different UHD movie. Now its saying "The source file '/BDMV/STREAM/00278.m2ts' is corrupt or invalid". The disc itself is spotless. Just what is going on ?
#19 Post by Billycar11 » Tue Jan 04, 2022 12:24 am
Yeah if its on multiple disc your new drive is defective return it and get a BU40N
zarc987
#20 Post by zarc987 » Tue Jan 04, 2022 12:26 am
Billycar11 wrote: Tue Jan 04, 2022 12:24 am Yeah if its on multiple disc your new drive is defective return it and get a BU40N
Im on a budget. What budget ones you recommend ?
#21 Post by Billycar11 » Tue Jan 04, 2022 12:28 am
The BU40N
BP50
Bp60
Or any other clones of those they can be gotten for around $80-$90.
I don't recommend any of the 5.25 drives from LG or Asus they are the same.
zarc987
#22 Post by zarc987 » Tue Jan 04, 2022 4:18 am
Billycar11 wrote: Tue Jan 04, 2022 12:28 am The BU40N
BP50
Bp60
Is it possible that I reset the firmware back to its original and re-flash it ?
#23 Post by MartyMcNuts » Tue Jan 04, 2022 4:22 am
zarc987 wrote: Tue Jan 04, 2022 4:18 am
BP50
Bp60
You could try but no need to go back to original. Just reflash NS60 1.02-MK and see if that helps.
zarc987
#24 Post by zarc987 » Tue Jan 04, 2022 4:32 am
MartyMcNuts wrote: Tue Jan 04, 2022 4:22 am
BP50
Bp60
May I ask, what about this one?
HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010
#25 Post by Billycar11 » Tue Jan 04, 2022 5:37 am
zarc987 wrote: Tue Jan 04, 2022 4:32 am
you can try it but it likely wont fix anything
zarc987
#26 Post by zarc987 » Thu Jan 06, 2022 1:50 am
BP50
Bp60
IF you were to recommend a LG or ASUS one, what would you say is a good one ?
#27 Post by MartyMcNuts » Thu Jan 06, 2022 3:23 am
zarc987 wrote: Thu Jan 06, 2022 1:50 am
BP50
Bp60
They are basically all the same. The ASUS is a rebadged LG anyway. Just go with the cheapest one.
