@all
I was testing some hdr10 patterns converted to DV and look what happen on the Shield/X700/C8 with this P8 pattern : https://slow.pics/c/tnFWN04T (there's definitely something wrong with P8/P7 DV on the shield)
Re-did the FEL test files as well, hopefully, they work better on different devices...
https://drive.google.com/drive/u/1/fold ... V0E3VVkhiC
staknhalo
Post by staknhalo »
RESET_9999 wrote:
Wed Dec 29, 2021 4:17 pm
Thanks for this - just going over the names - seems there's a p5 with incorrect/misaligned RPU or something so we can test DV RPU working on p5 only setups, was gonna ask for this eventually 8)
staknhalo wrote:
Wed Dec 29, 2021 4:41 pm
yep, some with hlg base layer as well
quietvoid
Post by quietvoid »
@all
Pattern looks decent on my firestick, though I can barely see the flashing blocks in the top PQ tracking.
good to know.
If the other devices don't have issues as well(which I expect), the pattern may be exposing the famous Shield color issues and Nvidia could finally be able to fix it.
stevenugent83
Post by stevenugent83 »
RESET_9999 wrote:
Wed Dec 29, 2021 3:22 pm
stevenugent83 wrote:
Sun Dec 26, 2021 10:15 pm
I wonder if anyone can help,
I have an LG CX,
Convert to profile 8 for playback on LG (CX +) oled TVs and then use TSmuxer or the MP4muxer. And If the first audio is TrueHD or DTSHD or DTS, DV won't work, so keep the first audio in AC3 or EC3 (or select it in plex before playback). PGS subtitles will fail to play DV TS as well but external SRT works (internal srt in mp4 works too).
viewtopic.php?f=12&t=18602&start=2970#p96282
Cheers, converting now. fingers crossed.
NiCE77
Post by NiCE77 »
@all
Thanks for the test files!
Can you make a P8 RPU test file with HLG base layer like iPhone recordings?
Allegedly, the latest version of Infuse handles these DV files natively and I want to test this to see if the RPU is actually used by the Apple TV 4K.
staknhalo
Post by staknhalo »
NiCE77 wrote:
Thu Dec 30, 2021 3:45 pm
@all
he has p8 hlg files in there
yes but the file has the 8.1 rpu from @quietvoid L1L2 HDR10 BL test file.
I'll try to edit the original HLG 8.4 footage.
vondy
Post by vondy »
I have been researching for about 3 days now and figured this might be the best place to ask this question. Going to keep it simple.
Can a 2019 Shield Pro play at Dolby Vision dual layer profile 7 file from a UHD disc correctly? Meaning will you get the full DV displayed without it converting to HDR10 or single layer DV.
My setup:
Plex Server running on Synology NAS (Direct Play) (MKV - nothing transcoded or anything)
2019 Shield Pro
Plex player on Shield
to NAD T 778
to LG OLED CX 77
NiCE77
Post by NiCE77 »
RESET_9999 wrote:
Thu Dec 30, 2021 7:42 pm
Thank you!
vkmekam
Post by vkmekam »
Manixx2020beyound wrote:
Tue Oct 05, 2021 5:20 am
staknhalo wrote:
Mon Oct 04, 2021 9:35 pm
quietvoid wrote:
Mon Oct 04, 2021 1:17 pm
Also it's complicated to keep it in sync with the BL.
Yeah as I mentioned previously, I have not been able to encode a single BL and mux back in its FEL (or even convert that FEL+then encoded BL to 8 ) without there being RPU sync errors/flashes in the file, somewhere, eventually (not always right at the start nor constant). I've tried x265/ffmpeg/though Staxrip UI/Handbrake/various encode settings multiple times/different rip and mux tools and differing versions of each program/yusesope's or quietvoid's tool - there's always a RPU errors eventually in a FEL title no matter what I do with it if I first encode the BL. MEL titles with encoded BL or 8 converted from 5 RPU + encoded HDR10 BL or HDR10+ to 8 with encoded BL - no problem whatsoever on any of those titles (I think I'm at mid-50s currently for native Dovi UHD titles I've added to Plex). I know others here say they're doing it, but I somehow am just SOL apparently. So any FEL title I just mux together and leave untouched - using external forced subs works fine in Plex so I don't need to worry about burning them in (main reason for encoding, secondary to the space saving aspect) - and being I have the source PGS subs, timing/spelling is accurate and all that jazz for my external subs, no worries.
Still, sucks being defeated :(
We are not defeated at all, there is a way,
I have just created a flawless copy of power rangers just for this test. FEL is 7gigs on power rangers don’t encode it.
18 gig base layer encode with FEL & RPU
You have to edit the FEL (has the nal unit) in the Rpu to reflect the hevc bl encode and that’s it.
I get no flashes no pixilation perfect alinement. Perfect profile 7 with encoded base layer
Inject the new Rpu into the FEL.
Mux with base layer in ts muxer nightly build & your done.
The hard part is getting a new Rpu.
Would you mind explaining which process you used to extract and merge the FEL after having re-encoded the HDR10 base layer and how do edit the RPU? Thank you kindly.
MastaG
Post by MastaG »
Did anybody ever got the older LG OLED 6 series (B6, C6 or E6) to trigger DV when muxed into .TS or .M2TS containers?
I'm remuxing them as profile 8 (mode 2) with the first audio track being the AC3 one and the second one HD-audio (just for preservation purposes).
They play fine on my C8, but not on these older models for some reason.
The only way to trigger DV on my brothers B6, was by using mp4muxer to mux the profile 8 hevc track + ac3 audio only.
However mp4 doesn't store HD-audio and I also find mp4muxer very slow compared to TSmuxer.
For the record I know I cannot play HD-audio on any of the LG televisions, it's just for preservation.
Perhaps these older 6-series require some flag or identify as profile 5 instead of 8?
Any help would be more than welcome :D
WaynosDaBoss
Post by WaynosDaBoss »
Hi! I am new here as just doing some research on playing DV mkv files via my LG C9 OLED and as there are 396 odd pages to read through I thought I would post as hopefully someone might be able to help me get the answer I am looking for!
I was trying to play some recently aquired DV content over the Plex app on the C9 OLED and noticed the picture was all green / purple and after a quick google discovered this was because the DV format is not being processed / played back correctly. I have done some more digging and found out the source file in question is H.265 DV Profile 5 with EAC3 Atmos which I know the TV supports when using the Netflix, Disney+ apps etc so the native player of the TV should be ok with this format. I then tried taking Plex out of the equasion and played the mkv file back directly from a USB stick and got the same result. I also read somewhere that it wouldnt work when DV is combined with Atmos so I converted the audio from eac3 to standard ac3, remuxed the file but again got the same result.
From what I have read so far it would appear dual layer files which use profile 7 are able to fall back to standard HRD10 and ignore the metadata but as this file is profile 5 single layer this is not possible.
Does anyone know if this file type should be supported or not or if I should just forget about the DV content and try to play standard HDR10 files instead or do I just have a bit of an oddball file here?
DolbyVisionFTW
Post by DolbyVisionFTW »
WaynosDaBoss wrote:
Sun Jan 02, 2022 9:53 pm
From my limited reading of this thread:
Profile 5 does not support HDR10 fallback.
P5 (always single layer) = none-tonemapped DV base layer(green and purple colours) + dynamic metadata in RPU.
