Transformers Movie (Animated) doesn't play properly
Not directly to UHD discs or the MakeMKV software.
I used AnyDVD HD to decrypt this movie that I own and outputted it as an ISO.
When I mount the ISO, PowerDVD 21 loads to play the file, but all I get is a black screen. When I use MakMKV to convert the file to mkv, it plays absolutely fine.
Not sure what the problem could be. I've often noticed, the file will mount twice even though I selected it the once.
Anyone have any ideas?
Thank you.
Thank you.
Re: Transformers Movie (Animated) doesn't play properly
maybe since official UHD support was removed it can no longer play UHD backups i know it worked in 19 and 20Smiggy wrote: Sun Jan 02, 2022 3:58 am Hello,
Thank you.
Hi,Billycar11 wrote: Sun Jan 02, 2022 4:47 ammaybe since official UHD support was removed it can no longer play UHD backups i know it worked in 19 and 20Smiggy wrote: Sun Jan 02, 2022 3:58 am Hello,
Thank you.
PowerDVD 21 still supports UHD. I have 18TB of UHD/4K content or movies and they all play fine except this file.
If the protection is removed it should play.
It sometimes starts for a few seconds, you can see the usual disclaimer and then freezes. Only when I extract the video as a mkv does it play fine.SamuriHL wrote: Sun Jan 02, 2022 5:12 am If the protection is removed it should play.
That sounds more like a powerdvd bug of some kind. Does the original disc play in powerdvd without anydvd running?
Yes, perfectly.SamuriHL wrote: Sun Jan 02, 2022 1:47 pm That sounds more like a powerdvd bug of some kind. Does the original disc play in powerdvd without anydvd running?
Try ripping it with MakeMKV backup functionality to a decrypted folder. Play it back from the folder and see what happens.
I didn't do anything and now it's working?
