DingusKahn8
Re: SDFtool Flasher
Just used this tool to flash my encrypted 1.04 BU40N to 1.03 and it worked like a charm. Super fast and easy. Thanks guys! Saved me so much time and headache.
Re: SDFtool Flasher
Admittedly my situation is a bit odd. I am using Windows 11 ARM on an M1 Mac under Parallels.
I haven't yet received my BW-16D1HT yet, but I thought I'd get ready. When I attempt to start the SDF tool, I get an exception:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at SDFtool_Flasher_Updated.Form1.Check_MakeMKV_Installation()
at SDFtool_Flasher_Updated.Form1.Form1_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
System.Private.CoreLib
Assembly Version: 6.0.0.0
Win32 Version: n/a
CodeBase:
Assembly Version: 1.3.0.0
Win32 Version: n/a
CodeBase:
System.Runtime
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Drawing.Primitives
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Drawing.Common
Win32 Version: n/a
CodeBase:
System.Threading
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Collections
Win32 Version: n/a
CodeBase:
System.Diagnostics.Process
Win32 Version: n/a
CodeBase:
Microsoft.Win32.Primitives
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Threading.Thread
Win32 Version: n/a
CodeBase:
Accessibility
Assembly Version: 4.0.0.0
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Numerics.Vectors
Win32 Version: n/a
CodeBase:
System.Memory
Win32 Version: n/a
CodeBase:
System.ComponentModel
Win32 Version: n/a
CodeBase:
System.Resources.Extensions
Win32 Version: n/a
CodeBase:
System.Drawing
Win32 Version: n/a
CodeBase:
System.ObjectModel
Win32 Version: n/a
CodeBase:
System.Linq
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Collections.Concurrent
Win32 Version: n/a
CodeBase:
mscorlib
Win32 Version: n/a
CodeBase:
Microsoft.Win32.SystemEvents
Win32 Version: n/a
CodeBase:
System.Collections.NonGeneric
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Private.Uri
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Xml.ReaderWriter
Win32 Version: n/a
CodeBase:
System.Private.Xml
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Net.WebClient
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Xml.XmlSerializer
Win32 Version: n/a
CodeBase:
Microsoft.Win32.Registry
Win32 Version: n/a
CodeBase:
System.Runtime.Loader
Win32 Version: n/a
CodeBase:
System.Diagnostics.StackTrace
Win32 Version: n/a
CodeBase:
System.Reflection.Metadata
Win32 Version: n/a
CodeBase:
System.Collections.Immutable
Win32 Version: n/a
CodeBase:
************** JIT Debugging **************
The resulting UI looks a bit malformed, although it does appear that all of the controls are present.
https://imgur.com/a/XEiFlsI
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Runtime
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Threading
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Collections
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Accessibility
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Memory
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Drawing
Win32 Version: n/a
CodeBase:
System.ObjectModel
Win32 Version: n/a
CodeBase:
System.Linq
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
mscorlib
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Private.Uri
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Private.Xml
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Re: SDFtool Flasher
I'm not sure it willl work that way.nsayer wrote: Thu Dec 30, 2021 5:55 am Admittedly my situation is a bit odd. I am using Windows 11 ARM on an M1 Mac under Parallels.
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Runtime
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Threading
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Collections
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Accessibility
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Memory
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Drawing
Win32 Version: n/a
CodeBase:
System.ObjectModel
Win32 Version: n/a
CodeBase:
System.Linq
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
mscorlib
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Private.Uri
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Private.Xml
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Anyway, to have any chance of it working, you must have MakeMKV installed in windows at the default location (C:\Program Files (x86)\MakeMKV).
The GUI may look a bit deformed if you are using a 4K monitor. You can right click the exe and select properties. In the compatibility tab, click "Change high DPI settings" then under "High DPI scaling override" tick the box and select "System (Enhanced)" in the dropbox.
Re: SDFtool Flasher
Ah, I wasn’t running it from the right place.
In the meantime, I did the flashing on the (Mac) host with the makemkv command line, so I’m good.
Re: SDFtool Flasher
Hi there,
I have had a successfully flashed BU40N drive for some time. I can write UHDs and can play them through DVDFab. However, I do have a small issue, that might not be an issue to some. I have installed the following;
OS device name: F:
Product: BD-RE BU40N
Revision: 1.00
Serial number: xx
Firmware date: 2116-12-20 15:28
Highest AACS version: 72
Firmware version: 1.00
My question is, does anyone else find these drives extremely loud? I am of course not objecting to this while writing UHD discs, however, whenever I am playing blu-rays and especially UHD blu-rays, the noise is a distraction for me.
Is there any way to change the read speed for playback only with these drives? or will I have to look at other firmware revisions? I don't want to rock the boat with potentially losing any playback abilities, but if this is a simple fix I would like to know what that is.
Thanks a lot for your work here.
OS device name: F:
Revision: 1.00
Serial number: xx
Re: SDFtool Flasher
Not tried the tool yet but the current one has some styling issues on high DPI screens, just wanted to pass that along:
Not sure how to get to the checkboxes on the left to select 'encrypted' etc
Re: SDFtool Flasher
I missed seeing this until after my post, yes, that seems to help a lotMartyMcNuts wrote: Thu Dec 30, 2021 9:09 pm
Re: SDFtool Flasher
I tried following the instructions for flashing my BP50NB40 with SVC:NB52, but for some reason it isn't working. It shows completed successfully but it doesn't update the firmware in the third step at all. This is the current drive information
OS device name: E:
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: SIM2121TE5408
Highest AACS version: 35
Firmware version: 1.03
Unrestricted read speed: YesRe: SDFtool Flasher
It looks like you flashed your drive successfully? Now try to rip an UHD.
Re: SDFtool Flasher
I'm getting this message when I try to flash my ASUS BW-16D1HT. What is this "MT1959"?
- SDFtool.png (129.86 KiB) Viewed 19741 times
Re: SDFtool Flasher
Your drive was manufactured in 2013 & HW ("MT1939") is too old to support UHD/the FW you are trying to flash. "MT1959" HW started showing up ~Oct 2015.
Re: SDFtool Flasher
Awesome! I'm glad that someone finally posted the pics of what happens when trying to flash an old drive. Hopefully now people might actually check these things before attempting to flash, although it's good to see that the SDFtool Flasher will stop them if they try!!d00zah wrote: Wed Jan 05, 2022 7:18 pm Your drive was manufactured in 2013 & HW ("MT1939") is too old to support UHD/the FW you are trying to flash. "MT1959" HW started showing up ~Oct 2015.
Re: SDFtool Flasher
@Coopervid, Nah, he's only on BP50NB40 1.03-MK, which isn't UHD capable.Coopervid wrote: Wed Jan 05, 2022 2:54 pm It looks like you flashed your drive successfully? Now try to rip an UHD.
@1337_Nerd, Did you follow the steps exactly? If so and step 3 is the issue, can you please try this for step 3.
3. Flash firmware BP60NB10_1.00_MK_HBD. (If you don't already have the hybrid firmware, here is the link: download/file.php?id=2143
If that doesn't work, try the below:
3. Check the box to include the boot loader and flash firmware BP60NB10 1.00-MK.
Let us know how you go and I'll edit the steps.
Re: SDFtool Flasher
I followed the steps exactly. I believe step 3 was the issue as the others seemed to change the drive information afterwards. I attempted both of the steps you recommended, flashing the firmware file from the link you sent as well as flashing the firmware and bootloader of the standard BP60NB10 file. Neither of those produced any results. It goes through the process and says it finished successfully, but does not show any changes when I pull up makemkv.
Re: SDFtool Flasher
Ok, thanks for the update. You might just have to hold off for a few days or so until we get a resolution for this.1337_Nerd wrote: Thu Jan 06, 2022 12:02 am I followed the steps exactly. I believe step 3 was the issue as the others seemed to change the drive information afterwards. I attempted both of the steps you recommended, flashing the firmware file from the link you sent as well as flashing the firmware and bootloader of the standard BP60NB10 file. Neither of those produced any results. It goes through the process and says it finished successfully, but does not show any changes when I pull up makemkv.
