Have a buffalo BRUHD-PU3-BK running BU40N-1.03. It has been working perfectly on all my UHD discs previously. However recently I got some new discs: ghostbusters i/ii 4k, animal house 4k, and goonies 4k. All of these give the same issues as if I had the orig fw and hitting copy protection errors. Looked around the forums to see if there is a newer version but still 1.03 is what people seem to recommend. Here is the error I get:
"002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while
issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at v/79B2&2&>5Y>W)/}:213130306
DEBUG: Code 0 at #:'-Gd^FRDq~O@:2Z=:29396552
DEBUG: Code 4 at #:'-Gd^FRDq~O@:2Z=:29394275
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive"
Using latest MakeMKV v1.16.5
Manufacturer: BUFFALO
Product: Optical Drive
Revision: 1.03
Serial number: MO7K6AD3127
Highest AACS version: 61
Firmware version: 1.03
Attached the log file from the animal house 4k failed attempt.
Any suggestions would be great and Happy New Year!
1337c0d3d00d
BUFFALO BRUHD-PU3-BK running BU40N-1.03 UHD disks failing
1337c0d3d00d
- MKB20_v76_National_Lampoon's_Animal_House_C02B.tgz
- (240.11 KiB) Downloaded 296 times
Re: BUFFALO BRUHD-PU3-BK running BU40N-1.03 UHD disks failing
Your drive is not getting enough power the light on top is red
Use both cables or buy a high powered USB hub.
