AACS host certificate is revoked by your drive...Failed
Tran101
Post by Tran101 »
I'm trying to backup a BD disc and this is the first time I've received this error in opening a disc. The log file is below.
MakeMKV v1.6.5 darwin(x86-release) started?Debug logging enabled, log will be saved as /Users/=====/MakeMKV_log.txt?Optical drive "DVD+R-DL HL-DT-ST DVDRW GA32N KC08" opened in OS access mode.?It's highly recommended to install DASPI kernel extension to improve performance.?Optical drive "BD-ROM HL-DT-ST BDDVDRW CT21N 1.00" opened in OS access mode.?Using direct disc access mode?Error 'OS error - posix:00404040' occurred while issuing SCSI command AD010..080002400 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130283?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29395356?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:121262003?Error 'OS error - posix:00404040' occurred while issuing SCSI command AD010..080002400 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130283?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29395356?DEBUG: Code 1 at HLl(W&5$]?thgv_~_<:121262003?Error 'OS error - posix:00404040' occurred while issuing SCSI command AD010..080002400 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130283?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29395356?DEBUG: Code 2 at HLl(W&5$]?thgv_~_<:121262003?Error 'OS error - posix:00404040' occurred while issuing SCSI command AD010..080002400 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130283?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29395356?DEBUG: Code 3 at HLl(W&5$]?thgv_~_<:121262003?Error 'OS error - posix:00404040' occurred while issuing SCSI command AD010..080002400 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130283?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29395356?DEBUG: Code 4 at HLl(W&5$]?thgv_~_<:121262003?Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0F908AE174C26361BA165B7F91E0F8FD6F0 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130743?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29394643?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:121262003?Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0CB194593C2644DD4A21B1260B17560ACB8 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130743?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29394643?DEBUG: Code 1 at HLl(W&5$]?thgv_~_<:121262003?Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..022EC6120F17FD5DA5B8B90EEE27FD5A5B3 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130743?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29394643?DEBUG: Code 2 at HLl(W&5$]?thgv_~_<:121262003?Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..004C9C0026C4840ACD46033ACBCD878990E to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130743?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29394643?DEBUG: Code 3 at HLl(W&5$]?thgv_~_<:121262003?Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..08E50E773C92F8AA624052C515D6C94F04E to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130743?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29394643?DEBUG: Code 4 at HLl(W&5$]?thgv_~_<:121262003?Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0120B5AA9F685A35686D9643A3DA9F23D65 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130743?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29394643?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:121262003?Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..00A37CC4E3FB64E73F907AD61E18550E18A to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130743?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29394643?DEBUG: Code 1 at HLl(W&5$]?thgv_~_<:121262003?Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0FAA8B2FAAD387BECD8125F8AB1E3DE859E to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130743?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29394643?DEBUG: Code 2 at HLl(W&5$]?thgv_~_<:121262003?Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..092FE3546D4B5BA26A251C1B6DCC5A30341 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130743?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29394643?DEBUG: Code 3 at HLl(W&5$]?thgv_~_<:121262003?Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0760F0E07C760DE9F65F9F37B00B44B5B0F to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130743?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29394643?DEBUG: Code 4 at HLl(W&5$]?thgv_~_<:121262003?Error 'OS error - posix:00404040' occurred while issuing SCSI command AD010..080002400 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130283?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29395356?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:121262003?Error 'OS error - posix:00404040' occurred while issuing SCSI command AD010..080002400 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130283?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29395356?DEBUG: Code 1 at HLl(W&5$]?thgv_~_<:121262003?Error 'OS error - posix:00404040' occurred while issuing SCSI command AD010..080002400 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130283?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29395356?DEBUG: Code 2 at HLl(W&5$]?thgv_~_<:121262003?Error 'OS error - posix:00404040' occurred while issuing SCSI command AD010..080002400 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130283?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29395356?DEBUG: Code 3 at HLl(W&5$]?thgv_~_<:121262003?Error 'OS error - posix:00404040' occurred while issuing SCSI command AD010..080002400 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130283?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29395356?DEBUG: Code 4 at HLl(W&5$]?thgv_~_<:121262003?Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..067D47CC13D76E7F7A86008B6945BE5575A to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130743?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29394643?Error 'OS error - posix:00404040' occurred while issuing SCSI command AD010..080002400 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130283?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29395356?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:121262003?Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..008B89B1515E5C350B423B197B9DB524971 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130743?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29394643?Error 'OS error - posix:00404040' occurred while issuing SCSI command AD010..080002400 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130283?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29395356?DEBUG: Code 1 at HLl(W&5$]?thgv_~_<:121262003?Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0C9AB03FACD517B502C5AFA7AE2E18066DF to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130743?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29394643?Error 'OS error - posix:00404040' occurred while issuing SCSI command AD010..080002400 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130283?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29395356?DEBUG: Code 2 at HLl(W&5$]?thgv_~_<:121262003?Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0947273599C8FC6B73DDD0BEA94F4CE1200 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130743?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29394643?Error 'OS error - posix:00404040' occurred while issuing SCSI command AD010..080002400 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130283?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29395356?DEBUG: Code 3 at HLl(W&5$]?thgv_~_<:121262003?Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0BE4092E636D643C808C369D2B6FA59720A to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130743?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29394643?Error 'OS error - posix:00404040' occurred while issuing SCSI command AD010..080002400 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130283?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29395356?DEBUG: Code 4 at HLl(W&5$]?thgv_~_<:121262003?Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0DA235F2A58C89C4D10A4E1F84CEFB34B6D to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130743?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29394643?Error 'OS error - posix:00404040' occurred while issuing SCSI command AD010..080002400 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130283?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29395356?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:121262003?Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..03E535E0B481F9D5160CDB9AA0E50D1CFF6 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130743?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29394643?Error 'OS error - posix:00404040' occurred while issuing SCSI command AD010..080002400 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130283?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29395356?DEBUG: Code 1 at HLl(W&5$]?thgv_~_<:121262003?Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..08F256AF4D5C6B14A3EA147F0CB54D47C87 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130743?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29394643?Error 'OS error - posix:00404040' occurred while issuing SCSI command AD010..080002400 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130283?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29395356?DEBUG: Code 2 at HLl(W&5$]?thgv_~_<:121262003?Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..07BC6FEF60F4722666514DE7477CB303F3E to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130743?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29394643?Error 'OS error - posix:00404040' occurred while issuing SCSI command AD010..080002400 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130283?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29395356?DEBUG: Code 3 at HLl(W&5$]?thgv_~_<:121262003?Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0252D566A83A21D9BE7687F4198D95914F5 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130743?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29394643?Error 'OS error - posix:00404040' occurred while issuing SCSI command AD010..080002400 to device 'OS:IOBDServices:3a07d02567717dbc:HL-DT-ST BDDVDRW CT21N 1.00'?DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130283?DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29395356?DEBUG: Code 4 at HLl(W&5$]?thgv_~_<:121262003?Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive?The volume key is unknown for this disc - video can't be decrypted?DEBUG: Code 0 at }m7#Kt#@~Q`L;5-0:121263590?DEBUG: Code 0 at }m7#Kt#@~Q`L;5-0:29396943?Failed to open disc
Re: AACS host certificate is revoked by your drive...Failed
Post by mike admin »
Can you run it with DASPI and see if error changes?
Tran101
Post by Tran101 »
With DASPI enabled:
Debug log started at Thu Feb 17 13:48:40 2011 , written by MakeMKV v1.6.5 darwin(x86-release)
001005:0000 MakeMKV v1.6.5 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/=====/MakeMKV_log.txt
001003:0020 DEBUG: Code 5 at YfjF{";&#,B-2r:29395563
001003:0020 DEBUG: Code 83886085 at +>@PH894}5 iZK1(:213131502
001003:0020 DEBUG: Code 0 at +>@PH894}5 iZK1(:213131088
001003:0020 DEBUG: Code 0 at ARlDRF+g!QZO/)&:213130605
002014:0000 Optical drive "BD-ROM HL-DT-ST BDDVDRW CT21N 1.00" opened in DASPI mode.
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command AD010..080002400 to device 'DASPI:IODASPIService:4f18ef39306ac3f7:'
001003:0020 DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130283
001003:0020 DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29395356
001003:0020 DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:121262003
001003:0020 DEBUG: Code 1 at HLl(W&5$]?thgv_~_<:121262003
001003:0020 DEBUG: Code 2 at HLl(W&5$]?thgv_~_<:121262003
001003:0020 DEBUG: Code 3 at HLl(W&5$]?thgv_~_<:121262003
001003:0020 DEBUG: Code 4 at HLl(W&5$]?thgv_~_<:121262003
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0160D5CFE15BE337772F8A3FD690D3AFB1F to device 'DASPI:IODASPIService:4f18ef39306ac3f7:'
001003:0020 DEBUG: Code 0 at >eEFJFu*~N:Al_'~2:213130743
001003:0020 DEBUG: Code 0 at HLl(W&5$]?thgv_~_<:29394643
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0A679CC61220AA45D3BFBD55F7703852D46 to device 'DASPI:IODASPIService:4f18ef39306ac3f7:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0851A78822FEB98363B9869365C1DC6A7B5 to device 'DASPI:IODASPIService:4f18ef39306ac3f7:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0F6B045BDB20F01C49B6286E68F299D6AD9 to device 'DASPI:IODASPIService:4f18ef39306ac3f7:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..03C84E5C6D807B4D38DB6688235B595B884 to device 'DASPI:IODASPIService:4f18ef39306ac3f7:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..05A498D539048F637219E4CE3CA6D468225 to device 'DASPI:IODASPIService:4f18ef39306ac3f7:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0975190979D3E5E496BD262900BC269037C to device 'DASPI:IODASPIService:4f18ef39306ac3f7:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0414352DAD24D0113314EDA9DA927B076A9 to device 'DASPI:IODASPIService:4f18ef39306ac3f7:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0BF39CFC6AF74C02EDC2FC3105A6530B16E to device 'DASPI:IODASPIService:4f18ef39306ac3f7:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B33DBD0906527EF3283380FE059B42D634 to device 'DASPI:IODASPIService:4f18ef39306ac3f7:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0D89E474F9839A110B90EB5EAAD65E80E3C to device 'DASPI:IODASPIService:4f18ef39306ac3f7:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..035F0C2FCD26340D2A7B536BD3495BD45DB to device 'DASPI:IODASPIService:4f18ef39306ac3f7:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0C1D86266AE3A105EFBCF17580F5C120D7F to device 'DASPI:IODASPIService:4f18ef39306ac3f7:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..04FBDFA516DC810C2C61663FD07954A058C to device 'DASPI:IODASPIService:4f18ef39306ac3f7:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..06ACAB7C69F9D01942D396FFA61AD82B9B6 to device 'DASPI:IODASPIService:4f18ef39306ac3f7:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..098D1CD5AF5E8A3B5586834DEA83E249F15 to device 'DASPI:IODASPIService:4f18ef39306ac3f7:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0A92E16F58B857F03C85076B5DC3523E1EB to device 'DASPI:IODASPIService:4f18ef39306ac3f7:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0ADAFF924615259F8B91F97998140753BC7 to device 'DASPI:IODASPIService:4f18ef39306ac3f7:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E222CD3F81C60EE035BAE2FEBADE4169C0 to device 'DASPI:IODASPIService:4f18ef39306ac3f7:'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0019B1969D0EBDDEEC635D7D8AA1624C1E5 to device 'DASPI:IODASPIService:4f18ef39306ac3f7:'
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at }m7#Kt#@~Q`L;5-0:121263590
001003:0020 DEBUG: Code 0 at }m7#Kt#@~Q`L;5-0:29396943
Thanks a lot. It's a bug in your drive firmware. Workaround will be added in a next version.
Tran101
Post by Tran101 »
Thanks! Any ETA?
Tran101 wrote:Thanks! Any ETA?
I take it back, your drive seems to be fine. Please try with latest DASPI 1.2. and see if anything changes at all.
