large file
fpefpe
large file
Post by fpefpe »
Hello --- I just ripped a blu-ray disc. makemkv generated over 20 files --- I found the the large file (14gb) and assume that was the movie. I started up vlc to play it, but VLC keep toggling between play and pause --- after about a minute I stop vlc ----
now, my computer is old and slow, but its running win 10 --- is the size of this file causing the issue or was the disc not ripped correctly?
thanks
Re: large file
Perhaps your computer's storage wasn't fast enough to play the file? Or, perhaps the CPU isn't powerful enough to play the file without stuttering?
Do you have other blu-ray rips you've successfully played on your computer?
fpefpe
Re: large file
Post by fpefpe »
not exactly ---- 23 files were ripped from this blu-ray disc, the size range from 245K to 14G --- all the files, ever the 7g file file plays fine --- I will try this on a faster computer to see if its this old laptop
Re: large file
fpefpe wrote:
Wed Dec 29, 2021 3:13 am
tell us the specs i will know if the cpu/gpu has h.264 decoding for bluray playback
fpefpe
Re: large file
Post by fpefpe »
As it turns out I have the LG WH16NS40 --- I put in an usb3 enclosure and run it as a usb3 device
Here is the info from psinfo64.exe
  • Kernel version: Windows 10 Pro, Multiprocessor Free
    Product type: Professional
    Product version: 6.3
    Service pack: 0
    Kernel build number: 19044
    System root: C:\WINDOWS
    Processors: 2
    Processor speed: 2.3 GHz
    Processor type: AMD Turion(tm) II Ultra Dual-Core Mobile M600
    Physical memory: 3586 MB
    Video driver: ATI Radeon HD 3200 Graphics
Re: large file
fpefpe wrote:
Wed Dec 29, 2021 4:05 am
    Service pack: 0
    Processors: 2
seems a mobile 3200 would have h.264 decoding maybe only 4gis of ram and a dual core cpu cant feed it fast enough
fpefpe
Re: large file
Post by fpefpe »
thx for the info --- I was able to play the disc using (other) blu-ray player software with out issue --- I check to see if my other faster computer can play the file
fpefpe
Re: large file
Post by fpefpe »
Billycar11 wrote:
Wed Dec 29, 2021 4:15 am
    Service pack: 0
    Processors: 2
Hello --- I copied the file to my desktop --- which has 16g memory and proc speed is 3.2 --- and the results were the same --- at this point all I can say it seems that the rip of the disc was bad ---- thx again for your help
