large file
fpefpe
large file
Post by fpefpe » Wed Dec 29, 2021 2:55 am
Hello --- I just ripped a blu-ray disc. makemkv generated over 20 files --- I found the the large file (14gb) and assume that was the movie. I started up vlc to play it, but VLC keep toggling between play and pause --- after about a minute I stop vlc ----
now, my computer is old and slow, but its running win 10 --- is the size of this file causing the issue or was the disc not ripped correctly?
thanks
Re: large file
Post by dcoke22 » Wed Dec 29, 2021 3:05 am
Perhaps your computer's storage wasn't fast enough to play the file? Or, perhaps the CPU isn't powerful enough to play the file without stuttering?
Do you have other blu-ray rips you've successfully played on your computer?
fpefpe
Re: large file
Post by fpefpe » Wed Dec 29, 2021 3:13 am
not exactly ---- 23 files were ripped from this blu-ray disc, the size range from 245K to 14G --- all the files, ever the 7g file file plays fine --- I will try this on a faster computer to see if its this old laptop
Re: large file
Post by Billycar11 » Wed Dec 29, 2021 3:21 am
fpefpe wrote: Wed Dec 29, 2021 3:13 am not exactly ---- 23 files were ripped from this blu-ray disc, the size range from 245K to 14G --- all the files, ever the 7g file file plays fine --- I will try this on a faster computer to see if its this old laptop
tell us the specs i will know if the cpu/gpu has h.264 decoding for bluray playback
fpefpe
Re: large file
Post by fpefpe » Wed Dec 29, 2021 4:05 am
As it turns out I have the LG WH16NS40 --- I put in an usb3 enclosure and run it as a usb3 device
Here is the info from psinfo64.exe
  • Kernel version: Windows 10 Pro, Multiprocessor Free
    Product type: Professional
    Product version: 6.3
    Service pack: 0
    Kernel build number: 19044
    System root: C:\WINDOWS
    Processors: 2
    Processor speed: 2.3 GHz
    Processor type: AMD Turion(tm) II Ultra Dual-Core Mobile M600
    Physical memory: 3586 MB
    Video driver: ATI Radeon HD 3200 Graphics
Re: large file
Post by Billycar11 » Wed Dec 29, 2021 4:15 am
fpefpe wrote: Wed Dec 29, 2021 4:05 am As it turns out I have the LG WH16NS40 --- I put in an usb3 enclosure and run it as a usb3 device
    Service pack: 0
    Processors: 2
seems a mobile 3200 would have h.264 decoding maybe only 4gis of ram and a dual core cpu cant feed it fast enough
fpefpe
Re: large file
Post by fpefpe » Wed Dec 29, 2021 4:28 am
thx for the info --- I was able to play the disc using (other) blu-ray player software with out issue --- I check to see if my other faster computer can play the file
fpefpe
Re: large file
Post by fpefpe » Wed Dec 29, 2021 4:53 pm
Billycar11 wrote: Wed Dec 29, 2021 4:15 am
    Service pack: 0
    Processors: 2
Hello --- I copied the file to my desktop --- which has 16g memory and proc speed is 3.2 --- and the results were the same --- at this point all I can say it seems that the rip of the disc was bad ---- thx again for your help
