Re: SDFtool Flasher
freespace wrote:
Mon Dec 20, 2021 3:43 am
Thanks, at least I have a confirmation and could direct my energy someplace else.
So looking for a new drive - is it still the case that all drives that officially support playback of UHD can't be used to RIP them? No-exceptions that anyone is aware of?
That was never the case pick a drive from the guide list linked below
Re: SDFtool Flasher
The latest version of the SDFtool Flasher (v1.3.0) has a checkbox option to flash the boot loader with the main firmware to the drive (thanks @Billycar11 for letting me know this works). This is useful for the newer BP50NB40 with SVC: NB52.
It's also possible that other newer models may soon require this option. Anyway, we will all work it out together as we go!!
Re: SDFtool Flasher
MartyMcNuts wrote:
Tue Dec 21, 2021 5:28 am
thanks for the update Marty this will make it easy for everyone
Q1mkv@fluidmemory
Re: SDFtool Flasher
Post by Q1mkv@fluidmemory »
What firmware do I use to flash LG BP50NB40, ver:1.03, NB52? I have downloaded the SDFtool Flasher v1.3.0, and the mk-firmware-pack-20200720.
I have run the read Firmware and created a dump file, and now I need to "WRITE Firmware"
Thank you for any help you can provide.
Re: SDFtool Flasher
Q1mkv@fluidmemory wrote:
Thu Dec 23, 2021 6:46 pm
See guide linked below
Re: SDFtool Flasher
If you don't want to wait, I believe the steps are (using SDFtool Flasher v1.3.0):
1. Flash drive to BP50NB40 1.03-MK from the MK firmware pack.
2. For the next flash, check the box to also flash boot loader and select firmware BP60NB10 1.00-MK from the MK firmware pack.
Let me know if this works for you.
Edit:
If the above didn't work or you don't want to try it, the way Billy says works is below (using SDFtool Flasher v1.3.0):
2. Check the box to also flash boot loader and flash BP50NB40 1.03-MK again.
3. Now you can flash the drive to BP60NB10 1.00-MK from the MK firmware pack.
Re: SDFtool Flasher
Is the updated guide not showing?
NB52 to > BP50NB40-NB50-1.03MK with enc > BP50NB40-NB50-1.03MK with bootloader/full flash > BP60NB10 1.02MK or 1.00MK
That how I did it not sure if the way you posted will work but will be good to know
Re: SDFtool Flasher
Billycar11 wrote:
Thu Dec 23, 2021 10:26 pm
I didn't see it. I'll have another look.
Edit:
Yep, found it, Billy. I'll also update the first post.
marioman50
Re: SDFtool Flasher
Post by marioman50 »
Hello, I just want to make sure I am flashing the correct firmware for a drive I’ve just purchased (archgon MD-8107-U3-AC-B). My goal is to be able to play/rip/write 4K blu-rays.
I downloaded the MK firmware pack and I’ve come across the firmware named:
HL-DT-ST-BD-RE_BU40N-U100-3M01801-211910161036.bin
Is this the correct firmware for me? I’m using the SDFtool Flasher (v1.3.0). If I’m correct, I am supposed to select “WRITE Firmware”, select the .bin file I listed above, then click “START”.
If anyone can help, please let me know. I don’t want to brick my new drive by accident. Thanks!
Here is my full drive info:
OS device name: G:
Product: BD-RE BU40N
Revision: U100
Serial number: MO1L3UJ1757
Firmware date: 2119-10-16 10:36
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 0.U1003
Re: SDFtool Flasher
marioman50 wrote:
Mon Dec 27, 2021 6:17 am
OS device name: G:
Revision: U100
Yes, you can use that one or any other BU40N firmware. Your steps are correct.
marioman50
Re: SDFtool Flasher
MartyMcNuts wrote:
Mon Dec 27, 2021 11:11 pm
Thank you very much! 🙏
One last thing, out of all of the BU40N firmware options in the MK pack, is there one that is generally agreed upon as being the best, or does it not matter much?
Re: SDFtool Flasher
marioman50 wrote:
Tue Dec 28, 2021 9:01 am
It really depends on what software you use. I normally recommend BU40N 1.00 as it is compatible with the widest range of software. The MK versions generally only work with MakeMKV.
marioman50
Re: SDFtool Flasher
MartyMcNuts wrote:
Tue Dec 28, 2021 9:27 pm
Thanks, I didn’t know that.
I’ve also been using this drive to rip CDs with iTunes on my MacBook Pro. Will DE_LG_BU40N_1.00 from the DE-firmware-pack allow me to continue doing that? (I will be using a windows PC to flash it)
Re: SDFtool Flasher
marioman50 wrote:
Wed Dec 29, 2021 6:45 am
Yep.
marioman50
Re: SDFtool Flasher
MartyMcNuts wrote:
Wed Dec 29, 2021 9:46 am
Yep.
Thanks, I appreciate the help! :)
