Question on Flashing
I have a LG WH16NS40. On the tutorial site, I am confused as to how to find if my firmware is encrypted or not.
Re: Question on Flashing
Show us you MakeMKV info of your drive or run SDFtool Flasher as it will tell you if it is MT1959 and if it has encrypted firmware or not.
Hi, there. This is what it says.MartyMcNuts wrote: ↑Tue Dec 28, 2021 2:29 amShow us you MakeMKV info of your drive or run SDFtool Flasher as it will tell you if it is MT1959 and if it has encrypted firmware or not.
Product: BD-RE WH16NS40
Revision: 1.05
Serial number: KLZL5BG0826
Harware support: Yes
Firmware support: No
Firmware version: 1.05
Yes, 1.05 is encrypted. SDFtool Flasher can take care of it for you. The recommended fw for your drive is WH16NS60 1.02-MK from the MK firmware pack. It is the quickest and will remove the sleep bug.zarc987 wrote: ↑Wed Dec 29, 2021 4:19 pmHi, there. This is what it says.MartyMcNuts wrote: ↑Tue Dec 28, 2021 2:29 amShow us you MakeMKV info of your drive or run SDFtool Flasher as it will tell you if it is MT1959 and if it has encrypted firmware or not.
Revision: 1.05
Hi. I just want to make sure something. I have a LG WH16NS 4 0 and you said to use the WH16NS 6 0 firmware ??? Also in MK firmware pack, which of the following firmware do I use ?MartyMcNuts wrote: ↑Thu Dec 30, 2021 1:36 amYes, 1.05 is encrypted. SDFtool Flasher can take care of it for you. The recommended fw for your drive is WH16NS60 1.02-MK from the MK firmware pack. It is the quickest and will remove the sleep bug.zarc987 wrote: ↑Wed Dec 29, 2021 4:19 pmHi, there. This is what it says.MartyMcNuts wrote: ↑Tue Dec 28, 2021 2:29 am
Revision: 1.05
HL-DT-ST-BD-RE_WH16NS40-NS50-1.05-NM00900-212005061440
HL-DT-ST-BD-RE_WH16NS40-NS50-1.03-NM00600-211711211653
HL-DT-ST-BD-RE_WH16NS60-1.01-NM00100-211711202000
HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936
Yes. HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936zarc987 wrote: ↑Thu Dec 30, 2021 3:06 amHi. I just want to make sure something. I have a LG WH16NS 4 0 and you said to use the WH16NS 6 0 firmware ??? Also in MK firmware pack, which of the following firmware do I use ?MartyMcNuts wrote: ↑Thu Dec 30, 2021 1:36 amYes, 1.05 is encrypted. SDFtool Flasher can take care of it for you. The recommended fw for your drive is WH16NS60 1.02-MK from the MK firmware pack. It is the quickest and will remove the sleep bug.zarc987 wrote: ↑Wed Dec 29, 2021 4:19 pm
Revision: 1.05
HI. After using the firmware, I got this.MartyMcNuts wrote: ↑Thu Dec 30, 2021 9:00 pmYes. HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936zarc987 wrote: ↑Thu Dec 30, 2021 3:06 amHi. I just want to make sure something. I have a LG WH16NS 4 0 and you said to use the WH16NS 6 0 firmware ??? Also in MK firmware pack, which of the following firmware do I use ?MartyMcNuts wrote: ↑Thu Dec 30, 2021 1:36 am
Product: BD-RE WH16NS60
Revision: 1.02
Highest AACS version: 61
Firmware version: 1.02
Disc Information
Label: PACIFIC_RIM_UPRISING
Timestamp: 2018-05-01 22:56:50
Protection: AACS2.0/C v61
Data capacity: 84.46 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Then when I try to access the disc...it said THIS.
MakeMKV v1.16.5 win(x64-release) started
Using LibreDrive mode (v06.2 id=7FA2657C7667)
Saved AACS dump file as C:\Users\P/.MakeMKV/MKB20_v61_Pacific_Rim_Uprising_98F1.tgz
It said the patch was successful. What is going on ?!
Have you read the UHD FAQ? The Hashed Keys section?zarc987 wrote: ↑Thu Dec 30, 2021 11:13 pm
It said the patch was successful. What is going on ?!![]()
Make sure you have checked the box to enable internet access in MakeMKV preferences.zarc987 wrote: ↑Thu Dec 30, 2021 11:13 pmHI. After using the firmware, I got this.MartyMcNuts wrote: ↑Thu Dec 30, 2021 9:00 pmYes. HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936zarc987 wrote: ↑Thu Dec 30, 2021 3:06 am
Revision: 1.02
Disc Information
Number of layers: 3
Then when I try to access the disc...it said THIS.![]()
MartyMcNuts wrote: ↑Thu Dec 30, 2021 9:00 pmMake sure you have checked the box to enable internet access in MakeMKV preferences.
Hi, the box to enable internet access was checked. However, the rip had 3 mins left and then it said it failed. This LONG log showed up. I have a fresh OS, the blu ray disc and blu ray is NEW. I cleaned the blu ray disc cuz there WERE smudges. I don't get what is going on ???
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around
Hash check failed for file 00294.m2ts at offset 70097627136, file is corrupt.
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around
Hash check failed for file 00294.m2ts at offset 70097823744, file is corrupt.
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432610304, attempting to work around
Hash check failed for file 00294.m2ts at offset 70432647168, file is corrupt.
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around
Hash check failed for file 00294.m2ts at offset 70432843776, file is corrupt.
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432727040, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433003520, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433003520-70433015808, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433015808-70433021952, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433021952, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433052672, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433353728, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433353728-70433359872, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433359872-70433366016, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433366016-70433372160, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433028096-70433034240, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433366016-70433384448, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433593344, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433605632-70433611776, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433624064, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433636352, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433648640, attempting to work around
Failed to save title 0 to file C:/Users/P/Documents/Pacific Rim Uprising_t00.mkv
Encountered 4 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
0 titles saved, 1 failed
Either the disc is scratched or you need to give it a really good clean (soapy water and a microfibre cloth to dry it off).zarc987 wrote: ↑Fri Dec 31, 2021 2:54 amMartyMcNuts wrote: ↑Thu Dec 30, 2021 9:00 pm
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around Hash check failed for file 00294.m2ts at offset 70097627136, file is corrupt. The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around Hash check failed for file 00294.m2ts at offset 70097823744, file is corrupt. The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097602560, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70097694720, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432610304, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432610304, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432610304, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432610304, attempting to work around Hash check failed for file 00294.m2ts at offset 70432647168, file is corrupt. The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432610304, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around Hash check failed for file 00294.m2ts at offset 70432843776, file is corrupt. The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432610304, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432610304, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432610304, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432610304, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432610304, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432727040, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432727040, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433003520, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433003520, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433003520-70433015808, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433015808-70433021952, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433021952, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433052672, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433052672, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433353728, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433353728, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433353728-70433359872, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433359872-70433366016, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433366016-70433372160, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432610304, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432610304, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432610304, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432610304, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432610304, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433003520, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433028096-70433034240, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433353728, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433353728, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433353728-70433359872, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433359872-70433366016, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433366016-70433384448, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433593344, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433593344, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433593344, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433605632-70433611776, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433624064, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433636352, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70433648640, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432610304, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432610304, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432610304, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432610304, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432610304, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 70432714752, attempting to work around Failed to save title 0 to file C:/Users/P/Documents/Pacific Rim Uprising_t00.mkv Encountered 4 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/... 0 titles saved, 1 failed
Also, how is the drive connected?
It may also just be a case of the drive not liking that disc. It does happen. That's why most of us have 2+ drives.
clean the disczarc987 wrote: ↑Fri Dec 31, 2021 2:54 am
Hash check failed for file 00294.m2ts at offset 70097627136, file is corrupt.to work around
replace the disc
try different UHD discs
i should also add sometimes drives act funny after being flashed and not being shut down for like 10 mins try that first.
I connected through the SATA connectors. Inside the tower case. I have no idea how cleaner I can clean it. This is crazy.MartyMcNuts wrote: ↑Thu Dec 30, 2021 9:00 pmEither the disc is scratched or you need to give it a really good clean (soapy water and a microfibre cloth to dry it off).
Billycar11 wrote: ↑Fri Dec 31, 2021 3:00 amI cleaned the disc, even used a 2nd copy of it, the same error still exists. Its always towards the end, the last few mins it messes up.
Try a different UHD movie
If the same thing happens I would return or exchange the drive
