Sorry if this has been asked before, but I couldn't find any decent documentation or related forum posts.
I recently started using makemkvcon for all of my Blu-Ray ripping, since my Blu-Ray drive is now installed in a headless server, and I keep running into issues with file paths that have spaces in the folder or file name. Is there a special syntax for spaces in makemkvcon, or is the answer really to just use file and folder names without spaces in them?
makemkvcon: Syntax for Spaces in File/Path Names
taylor85345
Re: makemkvcon: Syntax for Spaces in File/Path Names
Should just be able to enclose the paths in quotes, as in:
The alternative is to escape the spaces, another "popular" way for shells to parse things:
It's the shell that is breaking up the arguments.
"This is a path with spaces in it"Code: Select all
This\ is\ a\ path\ with\ spaces\ in\ itMakeMKV Frequently Asked Questions
taylor85345
[edit] posted twice because I didn't know each reply needed mod approval. Please see comment below.
taylor85345
I am familiar with shell syntax, and that doesn't seem to be the problem. Below is the output from makemkvcon ripping to a directory with a space in the folder name.
Running the same command but using rips successfully as expected, but ripping to just returns the help text. I am using fish shell with syntax highlighting, so I can see that the formatting is correct (I have tested in bash as well as a sanity check).
For the record, I am using the current snap package of MakeMKV in Ubuntu Server 20.04.
❯ makemkvcon mkv disc:0 0 "/media/storage-2/Movies/The Hobbit"
MakeMKV v1.16.5 linux(x64-release) started
Use: makemkvcon [switches] Command [Parameters]
Commands:
info <source>
prints info about disc
mkv <source> <title id> <destination folder>
saves a single title to mkv file
backup <source> <destination folder>
backs up disc to a hard drive
f <args>
run universal firmware tool
reg <key string or file name>
enter registration key into program
Source specification:
iso:<FileName> - open iso image <FileName>
file:<FolderName> - open files in folder <FolderName>
disc:<DiscId> - open disc with id <DiscId> (see list Command)
dev:<DeviceName> - open disc with OS device name <DeviceName>
Switches: -r --robot - turn on "robot" mode, see http://www.makemkv.com/developers
"/media/storage-2/Movies"Code: Select all
"/media/storage-2/Movies/The Hobbit"For the record, I am using the current snap package of MakeMKV in Ubuntu Server 20.04.
taylor85345
I was able to resolve this by removing the snap package and compiling MakeMKV from source. I believe the problem is with the current package snap package, which I will report to the package maintainer.
I'd suggest letting the packager know. It's probably a restriction within the package (Mike does not maintain any packages other than what you can download from this site).
taylor85345
