Yeah you won't be able to flash it to a BP60 for now then. to read UHD.lordvader wrote: Sat Dec 18, 2021 10:49 am
Ugh! Looked at the box - and it has NB52 for it's SVC code. But I looks like I was able to flash an MK firmware onto it ...
Weird
Re: Ultimate UHD Drives Flashing Guide Updated 2021
Actually I have an idea to make that drive be flash able to bp60 email me if you want to experiment no guarantees but worth a trylordvader wrote: Sat Dec 18, 2021 10:49 amUgh! Looked at the box - and it has NB52 for it's SVC code. But I looks like I was able to flash an MK firmware onto it ...lordvader wrote: Fri Dec 17, 2021 4:48 am Hey all,
Just purchased a BP50NB40, and started the UHD flashing process.
I first flashed with the MK firmware using the SDF Flash tool (from the "The all you need firmware pack", and the following is what I've got:
Looks good.Code: Select all
Drive Information OS device name: E: Manufacturer: HL-DT-ST Product: BD-RE BP50NB40 Revision: 1.03 Serial number: SIK01L99G0500 Firmware date: 2120-05-07 09:17 Bus encryption flags: 17 Highest AACS version: 12 LibreDrive Information Status: Enabled Drive platform: MT1959 Firmware type: Patched (microcode access re-enabled) Firmware version: 1.03 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed
I then attempted to flash the BP60NB10 firmware. SDFTool gives me the following warning, but then proceeds to flash "OK". However, when opening MakeMKV, there's no change to the firmware - hence no UHD for me.
Have I missed something?
Weird
lordvader
Email sentBillycar11 wrote: Sat Dec 18, 2021 11:23 pmActually I have an idea to make that drive be flash able to bp60 email me if you want to experiment no guarantees but worth a trylordvader wrote: Sat Dec 18, 2021 10:49 amUgh! Looked at the box - and it has NB52 for it's SVC code. But I looks like I was able to flash an MK firmware onto it ...lordvader wrote: Fri Dec 17, 2021 4:48 am Hey all,
Weird
You could try cross-flashing it to BU40N 1.03-MK instead?? Not sure if it will work but give it a shot.Billycar11 wrote: Sat Dec 18, 2021 10:33 pmYeah you won't be able to flash it to a BP60 for now then. to read UHD.lordvader wrote: Sat Dec 18, 2021 10:49 am
Weird
lordvader
Do you mean HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934 ?MartyMcNuts wrote: Sun Dec 19, 2021 6:24 amYou could try cross-flashing it to BU40N 1.03-MK instead?? Not sure if it will work but give it a shot.Billycar11 wrote: Sat Dec 18, 2021 10:33 pmYeah you won't be able to flash it to a BP60 for now then. to read UHD.lordvader wrote: Sat Dec 18, 2021 10:49 am
Weird
Still nothing. It looks like the flash succeeds, but no change in firmware :/
well i now know how to flash those new NB 52 drives
i will document how to do it soon
just going to tell mike and Marty about the new protection method
Great news, Billy!Billycar11 wrote: Sun Dec 19, 2021 8:43 am well i now know how to flash those new NB 52 drives
gmandres
Thank you so much!Billycar11 wrote: Sun Dec 19, 2021 8:43 am well i now know how to flash those new NB 52 drives
Can't wait to see how to flash SVC NB52 for UHD.
Thanks,
G
I already posted it some optimizations may happen once Mike gets the firmware we are dumping it soon I got a drive with nb52gmandres wrote: Thu Dec 23, 2021 1:32 amThank you so much!Billycar11 wrote: Sun Dec 19, 2021 8:43 am well i now know how to flash those new NB 52 drives
Thanks,
G
mkvmikeyb
Thank you Billycar11!
captainbdsc
I have read the OP many times, and read through most if not all of the posts that have "WH16NS60" mentioned in them.
Before I try this and potentially brick my drive, I just wanted to double check that all my ducks are lined up...
It looks like all I need to do is run the latest SDFtool Flasher.exe and make sure it is set to load WH16NS60 1.02MK?
I have a Unitek "Y-1099NEW" external adapter
https://www.amazon.com/gp/product/B06WWLCYC3/
Here are the details on my drive:
MFG Date: NOV 2020
SVC CODE: NS60
Product: BD-RE WH16NS60
Revision: 1.03
Serial number: HIDDEN BECAUSE EVERYONE ELSE DOES?
Firmware date: 2120-05-08 10:10
Highest AACS version: 75
Harware support: Yes
Firmware support: No
MFG Date: NOV 2020
SVC CODE: NS60
Revision: 1.03
Yep.captainbdsc wrote: Mon Dec 27, 2021 3:13 am I have read the OP many times, and read through most if not all of the posts that have "WH16NS60" mentioned in them.
MFG Date: NOV 2020
SVC CODE: NS60
Revision: 1.03
captainbdsc
THANK YOU!MartyMcNuts wrote: Mon Dec 27, 2021 5:05 amYep.captainbdsc wrote: Mon Dec 27, 2021 3:13 am I have read the OP many times, and read through most if not all of the posts that have "WH16NS60" mentioned in them.
MFG Date: NOV 2020
SVC CODE: NS60
Revision: 1.03
nothrills
There is alot of information on this forum, thanks for everyone involved. I just want to check something, though. I bought a BH16NS40 with SVC NS51 and firmware 1.05 for only about EUR50 brand spanking new from a local shop. MakeMKV showed the following information:
Now, I figured that because this firmware is encrypted, I need to flash a 'MK' version to enable downgrade/crossflash, etc. This wasn't completely obvious (to me) while reading the guide, but I figured this from the MK firmware topic. So I flashed HL-DT-ST-BD-RE_BH16NS40-NS50-1.05-NM00600-212005061331.bin from the MK firmware package. Now MakeMKV reports the following:
So far, so good (I guess). Now: I also see the 'only firmware you need' package which contains HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin. This seems to be the recommended firmware according to the guide, while not specifically mentioned for BH16NS40 drives. Two questions:
a) Is this the best firmware also for my drive, and should I thus crossflash to WH16NS60-1.02-NM00100-211810291936 or stay on the BH16NS40-NS50-1.05-NM00600-212005061331 firmware that's currently loaded?
b) In the MK firmware package there's only 1.03 for the WH16NS60 (WH16NS60-1.03-NM00600-212005081010). While in the 'only firmware you need' there's only 1.02. Is there a reason 1.02 keeps being referred to as 'the one', and (out of curiosity) why?
OS device name: F:
Product: BD-RE BH16NS40
Revision: 1.05
Serial number: ***********
Firmware date: 2120-05-06 13:31
Firmware version: 1.05
OS device name: F:
Revision: 1.05
a) look here. Most prefer 1.00 of BH16NS60 which is in the DE firmware pack
viewtopic.php?f=16&t=22896
b) same
b) same
