nasuel
#5836 Post by nasuel » Fri Dec 24, 2021 12:36 pm
Hi folks,
i have a problem with the process to get an DV MP4 file running on the Apple TV 4k with iOS 15 and the latest Infuse release from the App-Store.
What i've done:
- Ripped the entire UHD Blu Ray with MakeMKV
- Extracted the M2TS File with TsMuxR
- Extracted the base Layer and the enhanced Layer from the M2TS file with `ffmpeg -i 00801.m2ts -c copy -map 0:0 bl.hevc -c copy -map 0:1 el.hevc`
- Extracted the RPU from the el.hevc with `./dovi_tool extract-rpu -i el.hevc -o rpu.bin`
- Re-Injected the RPU to the bl.hevc with `./dovi_tool inject-rpu -i bl.hevc --rpu-in rpu.bin -o bl.rpu.full.hevc`
- Created a MP4 File with `./mp4muxer_mac -o full.rpu.mp4 -i bl.rpu.full.hevc -i aud1.ac3 --media-lang deu -i aud2.ac3 --media-lang eng --dv-profile 5`
Infuse recognizes the File as DV File but when a start playback the TV shows only HDR. Here are the metadata informations of the final output file:
General
Complete name : full.rpu.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/dby1/isom)
File size : 44.9 GiB
Duration : 2 h 29 min
Overall bit rate : 42.9 Mb/s
Encoded date : UTC 2021-12-24 12:02:44
Tagged date : UTC 2021-12-24 12:02:44
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Bit rate : 42.0 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.211
Stream size : 44.0 GiB (98%)
Default : Yes
Alternate group : 1
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light Level : 696 cd/m2
Codec configuration box : hvcC+dvcC
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : ac-3
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 480 MiB (1%)
Language : German
Service kind : Complete Main
Default : Yes
Alternate group : 2
Audio #2
Format : AC-3
Codec ID : ac-3
Bit rate : 448 kb/s
Language : English
Default : No
Alternate group : 2
What i'm doing wrong in my process?
Thanks a lot
Regards and Merry Christmas
quietvoid
#5837 Post by quietvoid » Fri Dec 24, 2021 2:29 pm
nasuel wrote: Fri Dec 24, 2021 12:36 pm Hi folks,
Thanks a lot
You're trying to trick Infuse to think the file is profile 5 when it's not.
The Apple TV only supports profile 5 and profile 8.4, which are not HDR10.
staknhalo
#5838 Post by staknhalo » Fri Dec 24, 2021 6:57 pm
quietvoid wrote: Fri Dec 24, 2021 2:29 pmprofile 8.4
I wonder if they'll try to do OTA Dolby Vision in USA/Canada with HLG being part of ATSC 3.0?
nasuel
#5839 Post by nasuel » Fri Dec 24, 2021 7:13 pm
Thanks a lot
What steps have i to do to make the file to a Profile 5 file? I thought that was these two steps
Thanks a lot
Regards
quietvoid
#5840 Post by quietvoid » Fri Dec 24, 2021 7:26 pm
nasuel wrote: Fri Dec 24, 2021 7:13 pm What steps have i to do to make the file to a Profile 5 file? I thought that was these two steps
You can't, the video is still HDR10.
nasuel
#5841 Post by nasuel » Fri Dec 24, 2021 8:46 pm
quietvoid wrote: Fri Dec 24, 2021 7:26 pm
Okay, so that means at the moment it is not possible to create a backup of a Dolby Vision UHD BD to play on AppleTV with Dolby Vision, correct.
Thanks and regards
ad329
#5842 Post by ad329 » Sat Dec 25, 2021 3:45 am
nasuel wrote: Fri Dec 24, 2021 8:46 pm
Thanks and regards
Following up on this, I think this is correct but trying to figure out why this is the case? It's not the color space conversion, but for some reason the RPU can't be created? Why can't the RPU from a profile 8/7 be put on a profile 5 stream? Does it changed based on the color space or something? @yusescope said something about it here but I don't fully understand why - viewtopic.php?style=6&f=12&t=18602&start=2445#p90215
niteflyr
#5843 Post by niteflyr » Sat Dec 25, 2021 6:42 am
Therefore you are saying, that this has somehow tricked Media Info into reporting this as a DV profile 5 video, but not really. Infuse knows better? Is there anyway possible to get an MKV DV rip, to profile 5 to play on ATV4K via Infuse?
quietvoid
#5844 Post by quietvoid » Sat Dec 25, 2021 2:12 pm
ad329 wrote: Sat Dec 25, 2021 3:45 am Following up on this, I think this is correct but trying to figure out why this is the case? It's not the color space conversion, but for some reason the RPU can't be created? Why can't the RPU from a profile 8/7 be put on a profile 5 stream? Does it changed based on the color space or something? @yusescope said something about it here but I don't fully understand why - viewtopic.php?style=6&f=12&t=18602&start=2445#p90215
When encoding profile 5, the video is encoded with a different colorspace, and is also reshaped from PQ to another custom transfer function.
This reshaping step generates metadata that is specific to that scene/frame.
Without both the original IPT colorspace video AND proper reshaping metadata, there is no way to have a correct profile 5 file.
If you use a different RPU from the one made specifically for the profile 5 video, it would not look correct.
niteflyr wrote: Sat Dec 25, 2021 6:42 amTherefore you are saying, that this has somehow tricked Media Info into reporting this as a DV profile 5 video, but not really. Infuse knows better? Is there anyway possible to get an MKV DV rip, to profile 5 to play on ATV4K via Infuse?
What you did is to remux the video into MP4, and the container tells Infuse "this here file should be profile 5".
However the actual video remains unchanged, and is still HDR10.
I don't know how Infuse sees it, but the actual device is the one ignoring the metadata.
There's no way as of today to convert it to profile 5.
Just play it as HDR10 or use another playback device which supports PQ based Dolby Vision such as profile 7 or 8.1.
Ride_UL
#5845 Post by Ride_UL » Sat Dec 25, 2021 3:59 pm
chros wrote: Sat Oct 09, 2021 8:44 am process:
# run madvr madmeasure on the mkv file
# generate RPU from madmeasure bin file
dovi_tool.exe generate -j generator_madvr.json --madvr-file l_0201.bin -o RPU_from_madVR.bin
# extract hevc video and audio with mkvextract
# inject the generated RPU into stream
dovi_tool.exe inject-rpu -i video.hevc --rpu-in RPU_from_madVR.bin -o injected_output.hevc
# mux together with tsmuxer
I'm was just trying to convert a HDR10 movie to DV P6 but got stuck with Step 2
Downloaded madVR, installed it & LAVfilters, copied madMeasureHDR to the madVR installation folder and got the .measurements file by running the mkv file through madMeasureHDR
Can you help me with the madmeasure bin file, how we can generate it?
Sorry, if i sound too noob
@@quietvoid
chros
#5846 Post by chros » Sat Dec 25, 2021 5:22 pm
Ride_UL wrote: Sat Dec 25, 2021 3:59 pm
@@quietvoid
That *. measure* file is the bin (binary) file, I just renamed it to *. bin
chros
#5847 Post by chros » Sat Dec 25, 2021 5:27 pm
quietvoid wrote: Sat Dec 25, 2021 2:12 pm
That's interesting, I didn't know about reshaping, thanks.
So, does dovi_tool take care of reshaping when a P5 RPU is converted into P8?
quietvoid
#5848 Post by quietvoid » Sat Dec 25, 2021 5:57 pm
chros wrote: Sat Dec 25, 2021 5:27 pm That's interesting, I didn't know about reshaping, thanks.
It discards the reshaping metadata, so yes.
RonRicoSuave
#5849 Post by RonRicoSuave » Sat Dec 25, 2021 8:24 pm
ArArdin wrote: Wed Dec 22, 2021 1:34 pm
DolbyVisionFTW wrote: Wed Dec 22, 2021 10:18 amOr is the conclusion that Chinoppo is still the only player that properly support FEL playback?
Ugoos AM6+ has a 2nd decoder so is able to playback FEl (from dual track mp4) but it's a very buggy player.
You may want to ask yourself how many tv's support full 12 bit processing. And then yet, those 12bit colors will be downscaled within max luminance capacity of the screen. TBH, I think that nowadays tv's will not hit enough nits to even support 10 bit to its full brightness.
DolbyVision's processing requires an upconversion to at least 14 bits in HDR space which is then mapped down to 12 then finally what the TV can actually manage, so any dv capable set can process it. Profile 8.1? I think it is (SDR BL, never actually seen one) is required to map the Rec. 709 BL up to 17 bits before performing a huge mess of color transformations. Most of the 17 bits is probably to avoid rounding errors propagating through the colorspace transforms, but still... I'd suspect the Rec.709 variant of HLG with profile 8.4 needs to do something similar, but I can't find any solid specs on that and it seems to mostly be a marketing ploy by Apple (editing in any of their software invalidates and removes the RPU), although it was technically allowed by spec for quite a while before they put it out there.
Similarly most current panels can accept 12bpc 4:4:4 or 4:2:2 over HDMI but as of yet there aren't any hardware decoders that can handle any form of HEVC Main12 that I'm aware of so this mainly applies to generated graphics (games, although none I'm aware of yet) and probably some raw formats of video that can decode in software smoothly given fast enough storage (or player-output DV).
I have nothing to test that with so take it with a grain of salt.
Ride_UL
#5850 Post by Ride_UL » Sun Dec 26, 2021 6:33 am
chros wrote: Sat Dec 25, 2021 5:22 pm
@@quietvoid
Thanks, it worked :)
