Dune 2021 Dolby Vision RPU Error
mtotheb
Post by mtotheb »
Hello everybody
The RPU File extracted from the Dune 2021 (BL+MEL) Disc with Dovi Tool gives the error "No frame number to look up" and I can't inject it into the Base Layer either.
Has anybody also enountered this issue?
quietvoid
Re: Dune 2021 Dolby Vision RPU Error
Post by quietvoid »
mtotheb wrote: Fri Dec 24, 2021 6:50 pm Hello everybody
That means you forgot to specify a frame using info. See example: https://github.com/quietvoid/dovi_tool#info
As for the inject part you'll need to be clearer.
mtotheb
Post by mtotheb »
quietvoid wrote: Fri Dec 24, 2021 8:04 pm
It says “Error: invalid PPS index”
Also thanks for all the work you’ve done in this community!
Shield TV 2017 -> LG DSN10YG Soundbar with SPK8 Rears -> LG B1 OLED
quietvoid
Post by quietvoid »
What command line are you using?
This sounds a lot like you're maybe not using a raw HEVC stream.
mtotheb
Post by mtotheb »
quietvoid wrote: Fri Dec 24, 2021 8:57 pm What command line are you using?
CMD
I think I solved half of the problem. I got it to work when it comes to injecting the DV8.1 RPU into the original Base Layer. (My old demux was from Yuseope’s Tool and different file sizes for BL and EL)
I’ll try now with the X265 Compressed “BL” because that had the same problem from before and update this thread.
Thx!
quietvoid
Post by quietvoid »
mtotheb wrote: Fri Dec 24, 2021 9:04 pm
CMD
Thx!
I meant the options, so the whole command line, ex: dovi_tool inject-rpu ....
