That was never the case pick a drive from the guide list linked below
Re: SDFtool Flasher
Re: SDFtool Flasher
The latest version of the SDFtool Flasher (v1.3.0) has a checkbox option to flash the boot loader with the main firmware to the drive (thanks @Billycar11 for letting me know this works). This is useful for the newer BP50NB40 with SVC: NB52.
It's also possible that other newer models may soon require this option. Anyway, we will all work it out together as we go!!
Re: SDFtool Flasher
thanks for the update Marty this will make it easy for everyoneMartyMcNuts wrote: ↑Tue Dec 21, 2021 5:28 amThe latest version of the SDFtool Flasher (v1.3.0) has a checkbox option to flash the boot loader with the main firmware to the drive (thanks @Billycar11 for letting me know this works). This is useful for the newer BP50NB40 with SVC: NB52.
Q1mkv@fluidmemory
Re: SDFtool Flasher
What firmware do I use to flash LG BP50NB40, ver:1.03, NB52? I have downloaded the SDFtool Flasher v1.3.0, and the mk-firmware-pack-20200720.
I have run the read Firmware and created a dump file, and now I need to "WRITE Firmware"
Thank you for any help you can provide.
Re: SDFtool Flasher
See guide linked belowQ1mkv@fluidmemory wrote: ↑Thu Dec 23, 2021 6:46 pmWhat firmware do I use to flash LG BP50NB40, ver:1.03, NB52? I have downloaded the SDFtool Flasher v1.3.0, and the mk-firmware-pack-20200720.
Re: SDFtool Flasher
If you don't want to wait, I believe the steps are (using SDFtool Flasher v1.3.0):Q1mkv@fluidmemory wrote: ↑Thu Dec 23, 2021 6:46 pmWhat firmware do I use to flash LG BP50NB40, ver:1.03, NB52? I have downloaded the SDFtool Flasher v1.3.0, and the mk-firmware-pack-20200720.
1. Flash drive to BP50NB40 1.03-MK from the MK firmware pack.
2. For the next flash, check the box to also flash boot loader and select firmware BP60NB10 1.00-MK from the MK firmware pack.
Let me know if this works for you.
Edit:
If the above didn't work or you don't want to try it, the way Billy says works is below (using SDFtool Flasher v1.3.0):
2. Check the box to also flash boot loader and flash BP50NB40 1.03-MK again.
3. Now you can flash the drive to BP60NB10 1.00-MK from the MK firmware pack.
Re: SDFtool Flasher
Is the updated guide not showing?
NB52 to > BP50NB40-NB50-1.03MK with enc > BP50NB40-NB50-1.03MK with bootloader/full flash > BP60NB10 1.02MK or 1.00MK
That how I did it not sure if the way you posted will work but will be good to know
Re: SDFtool Flasher
I didn't see it. I'll have another look.Billycar11 wrote: ↑Thu Dec 23, 2021 10:26 pmIs the updated guide not showing?
Edit:
Yep, found it, Billy. I'll also update the first post.
marioman50
Re: SDFtool Flasher
Hello, I just want to make sure I am flashing the correct firmware for a drive I’ve just purchased (archgon MD-8107-U3-AC-B). My goal is to be able to play/rip/write 4K blu-rays.
I downloaded the MK firmware pack and I’ve come across the firmware named:
HL-DT-ST-BD-RE_BU40N-U100-3M01801-211910161036.bin
Is this the correct firmware for me? I’m using the SDFtool Flasher (v1.3.0). If I’m correct, I am supposed to select “WRITE Firmware”, select the .bin file I listed above, then click “START”.
If anyone can help, please let me know. I don’t want to brick my new drive by accident. Thanks!
Here is my full drive info:
OS device name: G:
Product: BD-RE BU40N
Revision: U100
Serial number: MO1L3UJ1757
Firmware date: 2119-10-16 10:36
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 0.U1003
OS device name: G:
Revision: U100
Re: SDFtool Flasher
Yes, you can use that one or any other BU40N firmware. Your steps are correct.marioman50 wrote: ↑Mon Dec 27, 2021 6:17 amHello, I just want to make sure I am flashing the correct firmware for a drive I’ve just purchased (archgon MD-8107-U3-AC-B). My goal is to be able to play/rip/write 4K blu-rays.
OS device name: G:
Revision: U100
marioman50
Re: SDFtool Flasher
Thank you very much!MartyMcNuts wrote: ↑Mon Dec 27, 2021 11:11 pmYes, you can use that one or any other BU40N firmware. Your steps are correct.
One last thing, out of all of the BU40N firmware options in the MK pack, is there one that is generally agreed upon as being the best, or does it not matter much?
Re: SDFtool Flasher
It really depends on what software you use. I normally recommend BU40N 1.00 as it is compatible with the widest range of software. The MK versions generally only work with MakeMKV.marioman50 wrote: ↑Tue Dec 28, 2021 9:01 amThank you very much!MartyMcNuts wrote: ↑Mon Dec 27, 2021 11:11 pmYes, you can use that one or any other BU40N firmware. Your steps are correct.
marioman50
Re: SDFtool Flasher
Thanks, I didn’t know that.MartyMcNuts wrote: ↑Tue Dec 28, 2021 9:27 pmIt really depends on what software you use. I normally recommend BU40N 1.00 as it is compatible with the widest range of software. The MK versions generally only work with MakeMKV.
I’ve also been using this drive to rip CDs with iTunes on my MacBook Pro. Will DE_LG_BU40N_1.00 from the DE-firmware-pack allow me to continue doing that? (I will be using a windows PC to flash it)
Re: SDFtool Flasher
Yep.marioman50 wrote: ↑Wed Dec 29, 2021 6:45 amThanks, I didn’t know that.MartyMcNuts wrote: ↑Tue Dec 28, 2021 9:27 pmIt really depends on what software you use. I normally recommend BU40N 1.00 as it is compatible with the widest range of software. The MK versions generally only work with MakeMKV.
marioman50
Re: SDFtool Flasher
Thanks, I appreciate the help!
