Pioneer BDR-XDO7UHD support?
Wayned
Post by Wayned »
I thought the BluRay drive I had (Toshiba Portable BD Writer SE-50S) was a 4K drive, it turns out it doesn't so I got the Pioneer drive. It turns out that MakeMKV doesn't support the Pioneer drive<sigh>. Is there a list of 4K drives that are supported?
This clown speaks for himself
Re: Pioneer BDR-XDO7UHD support?
Post by d00zah »
Ultimate UHD Drives Flashing Guide Updated 2021
see Recommended UHD Drives to get:
Linked below
Wayned
Post by Wayned »
one of them has been ordered, thank you
Wayned
Post by Wayned »
Arrrgh, I now have an Archon Ultra slim optical drive, model: MD-8107-U3 (missing the "S") and it doesn't work! Arrrgh
Wayned
Post by Wayned »
Now trying for the Buffalo drive
Wayned wrote: Sun Jan 02, 2022 11:52 pm Now trying for the Buffalo drive
dont get that one its so marked up i see them go for 180+ because its from japan.
might as well get one for from me that flashed and tested im in pa
but the Archgon one you need is this: https://www.amazon.com/gp/product/B07BC ... UTF8&psc=1
i have the USA model buffalo available for $164 fleshed tested to work with UHD and shipped
Wayned
Post by Wayned »
Too late. Is it hard to flash the Archgon(?) so that it would work?
Wayned
Post by Wayned »
I could cancel the order but I'd still have the Archon which doesn't work...
Wayned
Post by Wayned »
I could also cancel the new drive that I've ordered and I could send you the Archgon drive along with a check for (?amount?) and have you flash the drive or cross ship you have one on hand. That way I don't have another BluRay drive. Is this reasonable?
Wayned wrote: Sun Jan 09, 2022 2:38 pm I could also cancel the new drive that I've ordered and I could send you the Archgon drive along with a check for (?amount?) and have you flash the drive or cross ship you have one on hand. That way I don't have another BluRay drive. Is this reasonable?
Show us the makemkv drive info for the archgon I will tell you if it can be flashed to work
Wayned
Post by Wayned »
Here you go
Wayned wrote: Sun Jan 09, 2022 9:19 pmHere you go
No
The drive info section on the right side of makemkv
this
Wayned
Post by Wayned »
Oh, okay
