Getting Error 'Scsi error - NOT READY:MEDIUM NOT PRESENT - TRAY OPEN' error after 40 minutes of reading with no problem
geogan
Post by geogan » Wed Dec 22, 2021 9:14 pm
Trying to rip my new UHD Venom disc... all going well until 40 mins into it... then it popped out and then MakeMKV barfed looking for disc.
Why does the external Libredrive-enabled BU40N drive eject the disc in the middle of reading disc??
This is not the first time it has done this!
It got about 40 minutes into reading Venom (2018) 4K disc which is about 55GB and then failed. Total PITA having to start again from start.
I wish the program had some sort of a "resume" feature so it didn't have to start again reading the previous 30+GB of data again - surely it would be easy to find last point written to the file on computer that failed and start reading the disc again from same place?
The "Program reads data faster than it can write to disk" is maybe network congestion? - MakeMKV writes from local workstation PC (Ryzen 5950X) to movie server over 1GB Ethernet LAN connection.
EDIT: It worked without errors the second time after 1:03:33 - don't know what is causing this kind of randomness with this drive.
MakeMKV v1.16.5 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\xxxx/MakeMKV_log.txt
Downloading latest SDF to C:\Users\xxxx/.MakeMKV ...
DEBUG: Code 0 at 8;#?Xo?Z2-YVkV,<;:121261405
DEBUG: Code 0 at f>aOT?ps3!JZ64:R::29394873
Using LibreDrive mode (v06.2 id=FA108BB7DA63)
File 00001.mpls was added as title #0
File 00102.mpls was added as title #1
Title #00604.mpls has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00605.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00618.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00619.mpls has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00663.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00680.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00687.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00688.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00689.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00690.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00691.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00702.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00703.mpls has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00704.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00705.mpls has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00706.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00707.mpls has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00708.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00711.mpls is equal to title 00102.mpls and was skipped
Title #00720.mpls has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00721.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00734.mpls has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00735.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00780.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00797.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00811.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00812.mpls has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00813.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00814.mpls has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00815.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00816.mpls has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00817.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00818.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00819.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00820.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00821.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00083.mpls has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00827.mpls is equal to title 00001.mpls and was skipped
Title 00828.mpls is equal to title 00001.mpls and was skipped
Title 00836.mpls is equal to title 00001.mpls and was skipped
Title 00841.mpls is equal to title 00001.mpls and was skipped
Title #00100.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00001.m2ts was added as title #2
Title #00116.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00208.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00099.m2ts has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00600.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00601.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00602.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00603.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00604.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00605.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00606.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00607.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00608.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00609.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00610.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00611.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00612.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00613.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00614.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00615.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00616.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00617.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00618.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00619.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00620.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00621.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00622.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00623.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00624.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00625.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00626.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00627.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00628.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00629.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00630.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00631.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00632.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00633.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00634.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00635.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00636.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00637.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00638.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00639.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00640.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00641.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00642.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00643.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00644.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00645.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00646.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00647.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00648.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00649.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00650.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00651.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00652.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00653.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00654.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00655.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00656.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00657.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00658.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00659.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00660.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00661.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00662.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00663.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00664.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00665.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00666.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00667.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00668.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00669.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00670.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00671.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00672.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00673.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00674.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00675.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00676.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00677.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00678.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00679.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00680.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00681.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00682.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00683.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00684.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00685.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00686.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00687.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00692.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00693.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00694.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00695.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00696.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00697.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00698.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00699.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00700.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00701.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory //xxxx-htpc/Media 3/Staging/Venom (2018)
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
Error 'Scsi error - NOT READY:MEDIUM NOT PRESENT - TRAY OPEN' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '38005487616'
DEBUG: Code 0 at #:wLDVdI'c.knQMb:29398645
DEBUG: Code 1069 at cNBX)<Q1X_SK#?ad;`:213131341
DEBUG: Code 546 at cNBX)<Q1X_SK#?ad;`:213131341
Error 'OS error - {No Disk} There is no disk in the drive. Please insert a disk into drive hs' occurred while reading '\Device\CdRom0' at offset '37853257728'
DEBUG: Code 3221225491 at |v@gGwTzroP3Y(T6Kw:29395149
Error 'Scsi error - NOT READY:MEDIUM NOT PRESENT - TRAY OPEN' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '37853257728'
DEBUG: Code 100809218 at |v@gGwTzroP3Y(T6Kw:29395149
DEBUG: Code 0 at O{]l*x<upg.5#Kt)+A?Z:29395471
DEBUG: Code 0 at +j,$qy}{6LI[t,':zp\x:29394068
DEBUG: Code 0 at O{]l*x<upg.5#Kt)+A?Z:213131157
DEBUG: Code 0 at O{]l*x<upg.5#Kt)+A?Z:121262647
DEBUG: Code 18483036 at O{]l*x<upg.5#Kt)+A?Z:121261773
DEBUG: Code 0 at b'k_Gz0NVSfy&}LieHw>A:213129984
DEBUG: Code 0 at _Y+8iB|^MtysP|GFt:}V/:213137068
DEBUG: Code 1 at 3B#\%:BlUEu3k2A;:213132537
Failed to save title 0 to file //xxxx-htpc/Media 3/Staging/Venom (2018)/Venom (2018)_t00.mkv
0 titles saved, 1 failed
Re: Getting Error 'Scsi error - NOT READY:MEDIUM NOT PRESENT - TRAY OPEN' error after 40 minutes of reading with no prob
Post by dcoke22 » Wed Dec 22, 2021 9:47 pm
geogan wrote: Wed Dec 22, 2021 9:14 pm The "Program reads data faster than it can write to disk" is maybe network congestion? - MakeMKV writes from local workstation PC (Ryzen 5950X) to movie server over 1GB Ethernet LAN connection.
Have you tried writing to local storage? I think there are people on this forum that write to network storage from their optical media, but I rarely see logs with that 'reads data faster than it can write to disk' message. Over a 1Gb connection I wouldn't expect to see that when reading from the optical drive. Writing to local storage should eliminate this variable from your setup.
By the time MakeMKV prints the tray open message in the log, things have already gone wrong.
liechsowagan
Post by liechsowagan » Sun Jan 09, 2022 6:19 pm
dcoke22 wrote: Wed Dec 22, 2021 9:47 pm
I get this warning all the time. In my case, the bottleneck is not the network connection; rather, it's actually the HDD write speed at the server end. I have a RAID 5 volume constructed of WD Red Pros storing my data. The RAID controller overhead (from calculating parity data) is actually high enough to trigger this warning, so even local rips directly on the server trigger the message. I could eliminate the issue by introducing SSD caching, but that's a project for another day and a bigger budget since the warning is pretty harmless. In the meantime, it is still far more convenient for me to rip from my desktop over the network than locally from the server.
PC
-- Threadripper 3960X (24C/48Th @ 3.8 GHz)
-- 256 GB DDR4 3600
-- RTX 3080
-- Win 11 Pro
Software
-- MakeMKV v1.16.5
-- ProcMon v3.70
-- VLC v3.0.16
External Drives:
-- WH14NS40 (1.03 Stock)
-- WH16NS60 (1.02 Patched)
-- OWC Mercury Pro Cases
Post by dcoke22 » Mon Jan 10, 2022 9:13 am
liechsowagan wrote: Sun Jan 09, 2022 6:19 pm I get this warning all the time. In my case, the bottleneck is not the network connection; rather, it's actually the HDD write speed at the server end. I have a RAID 5 volume constructed of WD Red Pros storing my data. The RAID controller overhead (from calculating parity data) is actually high enough to trigger this warning, so even local rips directly on the server trigger the message. I could eliminate the issue by introducing SSD caching, but that's a project for another day and a bigger budget since the warning is pretty harmless. In the meantime, it is still far more convenient for me to rip from my desktop over the network than locally from the server.
That's sorta amazing. Personally, I run a software based RAID 5 on my desktop computer. There is some overhead calculating parity for writes, but it is barely noticeable on my computer from 2017. That 4 disk volume sustains reads and writes of 400+MB/s (when I'm not thrashing it with multiple reads & writes at once), but it is only used for storing my rips. Perhaps the volume you're writing to is busy with other workloads as well. Lots of seek time on rotational media can really impact throughput.
In any case, I was thinking you would run MakeMKV on your 'client' computer and store the output on that computer instead of on the network. Running MakeMKV on your server would undoubtedly be inconvenient. In the end, it doesn't matter since it worked for you the second time.
