Alright, thanks so much. When you say mux in bluray folder you mean only when adding subtitles?Kocal wrote: ↑Mon Dec 20, 2021 6:59 pmsure. I use this method: with tsmuxer, add the heaviest m2ts file from the bluray and mux in m2ts. (maybe you can just copy the m2ts file from the bluray and put it on a usb stick, without using tsmuxer idk. never tried.)dompidu wrote: ↑Sun Dec 19, 2021 9:03 amI have an LG G1 and Sony x700. Now, if I have a .iso of a 4K Bluray (dual layer DV), can I play it in its full glory by converting it to .m2ts (because .iso playback is not supported if I'm not mistaken)? If so, what is the exact process that I'd have to follow?
if you need subtitles, but don't want horrible subtitles, do this: add a srt file, go to the subtitles section, change font to size 20 (or what u want) and color to # 3a3a3a (or what u want). I use position between 88 (max position for black bar) and 0, change each time, to prevent burn in. Mux in blu-ray folder.
question: how can I play an mkv file dvhe.05.06, BL+RPU with lg cx and sony x700?
By the way, I found out that dvhe.05.06 is perfectly playable if in .mp4 through LG's Plex app. I guess this has already been talked about, but I'm happy it worked. Worked with S02E3 of The Witcher, but I supposed it's fine with others.
