jkatchy2
#5821 Post by jkatchy2 » Sat Dec 11, 2021 11:29 pm
RESET_9999 wrote:
Sat Dec 11, 2021 4:46 pm
jkatchy2 wrote:
Sat Dec 11, 2021 8:02 am
Any thoughts on Beelink Gt king Pro ? Will it play mkv files with dv profile 7 / 8 FEL with lossless audio from kodi 19.3 without any issues ?
damn another box to buy / test I guess lol
Spec wise looks similar to Ugoos AM6 Plus apart from S922X-H vs S922X-J , beelink gt king pro seems to have two ESS HIFI decoding chips for sound . Wonder the dolby vision files support . Though it mentioned as it supports DV.
stn17
#5822 Post by stn17 » Tue Dec 14, 2021 5:34 pm
Can any of these new Ugoos versions handle TV-led FEL? Buying a proper sound system for my C9 and kinda want to get advantage of TrueHD/Atmos, which is impossible in mp4.
Epedemic
#5823 Post by Epedemic » Fri Dec 17, 2021 10:09 am
Let me get something straight: Can the X700 properly play FEL DV in .ts or .m2ts format made by tsmuxer using the bl & el hevc files made by yousopee's beta tool?
I've been doing bluray folder structure from tsmuxer and renaming to AVCHD folder every damn time, so .ts/.m2ts would be much smoother :D
#5824 Post by RESET_9999 » Fri Dec 17, 2021 8:06 pm
Yes, most of them play fine but for an unknown reason, some don't work.
Epedemic
#5825 Post by Epedemic » Sat Dec 18, 2021 5:46 am
Amazing, thanks for clarifying.
One more question: Any advantage to using .m2ts over .ts (or the other way around)?
#5826 Post by RESET_9999 » Sat Dec 18, 2021 3:02 pm
no, none that I'm aware of.
dompidu
#5827 Post by dompidu » Sun Dec 19, 2021 9:03 am
I have an LG G1 and Sony x700. Now, if I have a .iso of a 4K Bluray (dual layer DV), can I play it in its full glory by converting it to .m2ts (because .iso playback is not supported if I'm not mistaken)? If so, what is the exact process that I'd have to follow? I also have some .mkv files but not sure if they are 7.06vhe or just profile 7.
What options do I have? I've been lurking for some time in this sub and there's so many things and discoveries every few weeks that I'm not exactly sure what's the path to follow. Also, didn't have an OLED TV up until now, so I'd like to get the max out of it.
Thanks for the help.
fox0910
#5828 Post by fox0910 » Sun Dec 19, 2021 9:12 am
I can use the subtitles in .m2ts (from .srt).
I have problems with the subtitles in .ts created with tsmuxer.
DolbyVisionFTW
#5829 Post by DolbyVisionFTW » Sun Dec 19, 2021 9:28 am
Which playback devices support playback of Dolby Vision 4K UHD Blu-ray full disc rips (in BDMV folder structure)?
Is it just the Oppo UDP-203 and clones or can some other Blu-ray players and media players also support full disc rips?
Thanks.
ArArdin
#5830 Post by ArArdin » Mon Dec 20, 2021 8:58 am
RTD 1619 based Dune and Zidoo mediaplayers play UHDBD folders/ISOs.
Kocal
#5831 Post by Kocal » Mon Dec 20, 2021 6:59 pm
sure. I use this method: with tsmuxer, add the heaviest m2ts file from the bluray and mux in m2ts. (maybe you can just copy the m2ts file from the bluray and put it on a usb stick, without using tsmuxer :D idk. never tried.)
if you need subtitles, but don't want horrible subtitles, do this: add a srt file, go to the subtitles section, change font to size 20 (or what u want) and color to # 3a3a3a (or what u want). I use position between 88 (max position for black bar) and 0, change each time, to prevent burn in. Mux in blu-ray folder.
question: how can I play an mkv file dvhe.05.06, BL+RPU with lg cx and sony x700?
chronomac
#5832 Post by chronomac » Mon Dec 20, 2021 8:44 pm
Apologies if this has been asked before - I did a quick search and didn't see anything: is there a way to convert an MKV with a DV profile 7 layer to one with 8.4? As far as I know, Apple TV supports HDR10 and DV profiles 5 and 8.4 (HLG+DV metadata) but not 7. I do know that 7 is HDR10 based and 8.4 is HLG, but I'm willing to transcode if necessary.
PlatypusW
#5833 Post by PlatypusW » Tue Dec 21, 2021 11:25 am
This won’t work if you want Dolby vision from my tests. Has to go through nightly tsmuxer first.
dompidu
#5834 Post by dompidu » Tue Dec 21, 2021 2:24 pm
Alright, thanks so much. When you say mux in bluray folder you mean only when adding subtitles?
By the way, I found out that dvhe.05.06 is perfectly playable if in .mp4 through LG's Plex app. I guess this has already been talked about, but I'm happy it worked. Worked with S02E3 of The Witcher, but I supposed it's fine with others.
Kocal
#5835 Post by Kocal » Wed Dec 22, 2021 2:19 am
I mux in blu-ray folder, but m2ts works fine with sub.
Unfortunately, .mkv dvhe.05.06 doesn't work with plex.
update: solved! just convert .mkv to m2ts with tsmuxer, works fine on x700
