Unable to Back-Up Spectre (Daniel Craig Collection 2021 Purchase)
charnathan
#1 Post by charnathan » Sun Dec 19, 2021 10:25 pm
Has anyone recently purchased the Daniel Craig Collection (Post November 2021) and been successful in making a back-up, or even a remux, of Spectre?
I've done all the necessary steps outlined in the forums here cleaning the disc (with a cloth, using water and soap, etc), but every time I'm getting an error when it's trying to copy the main movie title, "00037.m2ts". I've gone through 3 Disc's (2 from Best Buy and then 1 from Amazon), but still the same error every time.
I even tried to copy it directly from the disc and it also fails on the main movie title, "00037.m2ts".
Does anyone know if there is an issue with the manufacturing process? Does anyone know how I can find out the manufacturer and contact them?
Here's the error message:
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00037.m2ts' at offset '11455690752'
Failed to save title /BDMV/STREAM/00037.m2ts to file C:/Users/Computer Name/Desktop/Spectre (2015)/BDMV/STREAM/00037.m2ts
Encountered 6 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
EDIT: It's not a drive issue as I'm able to back-up other movies after trying to back-up Spectre.
Re: Unable to Back-Up Spectre (Daniel Craig Collection 2021 Purchase)
#2 Post by Billycar11 » Sun Dec 19, 2021 10:44 pm
if you cleaned the discs and got new discs
try cleaning your drive after that.
sorry but your drive is defective i recommend you return it if you can and get a BU40N
charnathan
#3 Post by charnathan » Sun Dec 19, 2021 11:05 pm
I thought it might be a drive issue too, but I'm am able to back-up other UHD and Blu-Ray discs.
It just seems to be an issue with that one.
rdgrimes
#4 Post by rdgrimes » Mon Dec 20, 2021 3:43 am
Those are 100GB triple-layer discs, generally troublesome to rip. Thorough vigorous cleaning/polishing will sometimes resolve it
charnathan
#5 Post by charnathan » Mon Dec 20, 2021 4:02 pm
Spectre is only a 2 layer disc according to MakeMKV
Disc Information
Label: SPECTRE
Timestamp: 2019-08-27 16:13:25
Protection: AACS2.0/C v72
Data capacity: 61.86 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
I think WB just has bad quality control with this current lot
charnathan
#6 Post by charnathan » Wed Dec 22, 2021 2:57 am
So I think it's just a bad batch isolated to the Spectre disc in the Daniel Craig Collection.
I bought Spectre separately and was able to back-up the issue with no issues.
philb1701
#7 Post by philb1701 » Sat Jan 08, 2022 11:00 am
I bought the Daniel Craig 4K Bond set and successfully made mkv files of all 4 movies and then transcoded with Handbrake without incident almost a year ago.
NeuroDawg
#8 Post by NeuroDawg » Thu Jan 13, 2022 8:46 pm
I got the same collection at Christmas time and had the exact same problem with Spectre. Cleaned the disc and drives (both of mine), and still no go. I did a return with Amazon. The new Spectre disc worked right off the bat.
