Crash processing BD+
Jytra
Re: Crash processing BD+
Post by Jytra »
Running into a similar problem. I use MakeMKV via a docker by Djoss for Unraid, and for some reason LOTR:ROTK Disc 2 gets to the section "BVMV/PLAYLIST/00452.mpls" and just straight up crashes the program. Even the newer release of 1.16.5 didn't seem to fix this issue.
thecross
Post by thecross »
mkvfann wrote: Wed Oct 20, 2021 4:41 am ...hard crash and then exit. This was on The Shawshank Redemption UHD...
I encountered a similar problem with the same title using MakeMKV version 1.16.5. I too spent time, more than I would like to admit, playing with various JRE versions. This made no difference.
It was possible to "backup" the encrypted contents of this title to a hard drive outside of MakeMKV using a "cp" style command after mounting the disk. I am not familiar with the makemkvcon syntax for "backing-up" or otherwise interacting with a title which has been "backed-up" into a folder structure in this manner so I opened the index.bdmv from a different PC via Samba which is running the same MakeMKV version (1.16.5) although the client is on Windows. This is what happened next:
MakeMKV v1.16.5 win(x64-release) started
The program can't find any usable optical drives.
Opening files on harddrive at Z:/PLEX/dragons/shawshank
Downloading latest HK to C:\Users\natrix/.MakeMKV ...
Saved AACS dump file as C:\Users\natrix/.MakeMKV/MKB20_v76_The_Shawshank_Redemption_B5DB.tgz
It appears as if the volume key is unknown. I believe this title is a somewhat recent release so I suppose this is not completely unexpected.
I carefully followed the instructions at:
viewtopic.php?f=12&t=24711
I sent the TGZ file for this title on November 9th. My DNS is functional. I am able to download the latest HK. There has been no change in the status of this title for me over the past several weeks.
What I find interesting is the different behavior between the Windows and Linux (command line) client of the same MakeMKV version when attempting to work with this title. Both clients fail to work with the title today on my systems, although the Windows client seems to fail significantly more gracefully as evidenced by the somewhat useful error message about the missing volume key. The Linux (command line) client does not produce this information when working with the same title, instead the client crashes with a "segmentation fault". I am able to work with other somewhat recent UHD releases with the Linux (command line) client so the problem appears to be unique to this particular title.
taylorwmj
Post by taylorwmj »
I, too, experienced this issue with this exact title a couple days back. Also played with JRE versions an for an embarrassing amount of time.
I ultimately did get it to work by setting the Java Custom executable to
/bin/true
Was such an important note that I saved it my internal wiki page for MMKV.
mkvfann
Post by mkvfann »
Just wanted to give a thanks to taylorwmj. This worked for me.
I'd love to see what is causing Java portion to crash before MakeMKV even gets a chance to load the disc, but this is a great workaround.
Jytra
Post by Jytra »
Gonna second that; Thanks, taylorwmj. Was having trouble with ROTK and recently Casino not loading because of a JRE error crashing my unRaid docker. Just adding that line bypassed the problem and let me finally get the rip done.
taylorwmj
Post by taylorwmj »
Just as an additional note: I would not recommend keeping the custom path set to `/bin/true`, but only switching to it when encountering issues.
katespace
Post by katespace »
taylorwmj wrote: Tue Nov 30, 2021 7:28 pm I ultimately did get it to work by setting the Java Custom executable to
/bin/true
THANK YOU! After updating java and banging my head against a wall didn't work, this worked perfectly.
sl1pkn07
Post by sl1pkn07 »
@mike admin know this issue?
greetinmgs
bhampster
Post by bhampster »
Thank you for figuring this out!
mrblobby
Post by mrblobby »
setting to /bin/true worked for me too , many thanks.
( I was re-ripping my extended version of LOTR discs which I've had for a long time, when I originally ripped them I didn't have any issues)
