MakeMKV fatal error macOS Monterey 12.01.1
sidekick2310
Post by sidekick2310 » Thu Dec 09, 2021 12:23 am
I just updated my MacBook Pro to Monterey 12.01.1 earlier today. When I opened up Make MKV this evening, an alert came up that says "Fatal error occurred, program will now exit." I'm assuming this means that the version of MakeMKV Beta I'm currently using (1.16.3) isn't compatible with Monterey. Is there another version of the program that I could download instead? Or is this potentially an issue that we expect to see resolved shortly?
Re: MakeMKV fatal error macOS Monterey 12.01.1
Post by Woodstock » Thu Dec 09, 2021 12:29 am
Have you tried the current version, 1.16.5?
Post by dcoke22 » Thu Dec 09, 2021 1:49 am
https://www.makemkv.com/download/
Version 1.16.4 was where Monterey support was added. As Woodstock said, 1.16.5 is current.
sidekick2310
Post by sidekick2310 » Thu Dec 09, 2021 7:00 pm
Thanks for the tip, I've installed the new version and everything appears to be working properly again.
mpreiss
Post by mpreiss » Sun Dec 19, 2021 3:19 am
1.16.5 didn't solve this for me. Running Monterey 12.1 on M1 macbook pro. I get the fatal error message too. I removed makemkv completely using appcleaner and reinstalled but no luck. Log results here:
Debug log started at Sun Dec 19 03:08:42 2021 , written by MakeMKV v1.16.5 darwin(arm64-release)
001005:0000 MakeMKV v1.16.5 darwin(arm64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///Users/mpreiss/MakeMKV_log.txt
Network access is ENABLED, CURL version 7.77.0/(SecureTransport) LibreSSL/2.8.3/1.42.0 (x86_64-apple-darwin21.0) , proxy server not set.
002010:0000 Optical drive "BD-RE HL-DT-ST BD-RE WH16NS60 1.00 KL5JALE1030d" opened in OS access mode.
003338:0000 Downloading latest SDF to /Users/mpreiss/Library/MakeMKV ...
001003:0020 DEBUG: Code 2400288796 at I_QLVP=?[ EkEZH:29393999
csf9 f=50331651
001003:0020 DEBUG: Code 3355705345 at |oEdM='>QF=~EUyo=:213131893
003339:0000 Automatic SDF downloading is disabled or failed.
001003:0020 DEBUG: Code 127 at v>%"\]s/O8Uz_,+E:121275642
Application exited at Sun Dec 19 03:09:59 2021
Post by dcoke22 » Sun Dec 19, 2021 9:13 pm
mpreiss wrote: Sun Dec 19, 2021 3:19 am 003339:0000 Automatic SDF downloading is disabled or failed.
I'm pretty sure that message means MakeMKV can't contact the server to download keys. The post linked below will show you have to figure that out.
viewtopic.php?f=12&t=24711
