Mattl0
Post by Mattl0 » Fri Dec 10, 2021 8:19 am
Why is the start time of tsmuxer always set to 4 seconds?
When writing hdr10 or dv (wich won’t work) with ffmpeg to a ts container it maitains the original start time of the m2ts file.
Even when converting a ts made from tsmuxer to another ts with ffmpeg , the original start time is set back.
PlatypusW
Post by PlatypusW » Fri Dec 10, 2021 2:14 pm
tr000 wrote:
Thu Dec 09, 2021 11:58 pm
You know what, I think I'm getting that "sinking feeling" with my recent purchase of the C1 after making these realizations. It seems to be a downgrade from my old TCL TV in this regard…the picture quality is amazing, but seriously, the way it handles formats is atrocious.
If you were expecting the tv to be a player then unfortunately yeah. But for me the CX is absolutely amazing, have no regrets. Would buy another instantly if I had to.
DaMacFunkin wrote:
Fri Dec 10, 2021 6:51 am
A source via HDMI will have the correct licensing so this will be allowed to ‘eARC’ out to the receiver.
This - an external player will be needed to get lossless audio though I’ve never tested lossless with earc, I assume it works though
eedwards86
Post by eedwards86 » Fri Dec 10, 2021 3:04 pm
Hello Everyone,
I’ve been reading through this thread and hoping to get a few answers if possible. Before I ask, let me reference the following equipment and files being used.
TV (DV): Sony A80J
TV (non DV/HDR10/HDR10+): Samsung Q6FN / Samsung TU8000
Plex: Version 1.25.0.5282
Storage: Synology DS1618+ (~32TB)
Streaming Players: Nvidia Shield Pro 2019, Amazon Firestick 4K, Amazon Firestick 4K Max
No AVR/Soundbar
Assets: All UHD/HDR created through MakeMKV, every DV file is dvhe.07.06 (FEL or MEL)
Question #1: For any UHD Dolby Vision discs ripped to MKV using version 1.15.3 or earlier, can those MKV's be re-run through a newer version of MakeMKV to retain DV information? Or do you have to go back to the disc?
Question #2: Any MKV file played on the shield using Plex would only display as HDR10 rather than Dolby Vision on my Sony A80J. All MKV’s were made on v1.15.2 to v1.16.5. I confirmed that other DV sources work (such as Disney+). It seems others have had luck with playback of varying DV profiles using Shield Pro including profile 7. I had no luck with any profile 7 files, I was curious if this is typical or an issue only on my end?
Question #3: DV will playback successfully on my Sony using Firestick 4K and 4K Max through Plex with the exception of any MKV with HDR10+. Those files display a black screen with audio only. I only had issues with one non-HDR10+ title that would display black video and audio only (2001: A Space Odyssey). All other DV mkv files playback successfully using Profile 7 regardless if FEL or MEL. Anyone else notice this issue with HDR10+ files?
Question #4: Possible bug found with Firestick 4K vs. the 4K Max. Playback of DV/HDR10+ mkv files work fine on both Samsung TV’s; both show movies playing in HDR10+. However, when attempting to play the same files through the 4K Max only black screen and audio play. This clearly looks like an issue with the 4K Max vs regular 4K; does anyone have any more information on this?
Based on the above does it make sense to transcode any of these assets to mp4 and/or attempt to change their DV profiles? I’m assuming you lose lossless audio when transcoding to mp4?
Poker354
Post by Poker354 » Sat Dec 11, 2021 1:01 am
Plex should work for profile 7 on the Shield but it is far from reliable. There are many times it can take 3 or 4 tries to trigger.
I highly recommend Just Player for playing DV on the shield.
jkatchy2
Post by jkatchy2 » Sat Dec 11, 2021 8:02 am
Any thoughts on Beelink Gt king Pro ? Will it play mkv files with dv profile 7 / 8 FEL with lossless audio from kodi 19.3 without any issues ?
daddy
Post by daddy » Sat Dec 11, 2021 11:32 am
Guys, don't forget that the real DV profile 7 is dual layer, 1:1 AND 1:1/4 , and that the "dvhe.07.06" in mkv is just a workaround to send the stream as a Dolby Vision one.
AFAIK dvhe.07 exist only in ts, m2ts or mp4 formats and the only players that can read it are the x700, M9xxx and LG series x7, x8, x9
Post by RESET_9999 » Sat Dec 11, 2021 4:46 pm
if you use a device that doesnt support FEL, indeed there's no point playing profile 7 rips. The shield and most of the streaming box are perfectly stable with SL p8/p5 mkv.
And you save tons of HDD space by removing the huge EL (sometimes).
damn another box to buy / test I guess lol
staknhalo
Post by staknhalo » Sat Dec 11, 2021 9:44 pm
lionhunter wrote:
Wed Dec 08, 2021 4:40 pm
Can you show me the metada of such a MP4 please? What video tracks it has, etc. I'm trying to determine whether CCwGT or Amazon FireCube 2nd gen is better for DV playback. ATM, they seem equally capable from my testing.
SL-DT p7 FEL mp4
lionhunter
Post by lionhunter » Sat Dec 11, 2021 10:22 pm
SL-DT p7 FEL mp4
Thank you, after updating to the latest Plex beta version, it seems Chromecast with Google TV is superior to Amazon FireCube when it comes to DoVi playback. It can play ST-DL fine, while FireCube can't. No dice for DT-DL tho. From what I've read in this topic (almost 50 pages lol), you guys are saying CCwGT also processes the EL layer as well, not just the RPU. One thing I am curious tho: why is my LG CX receiving a 8 bit signal while playing DoVi from CCwGT? Shouldn't it be 10 bit or 12 bit? Is it related to TV led Dolby Vision perhaps?
staknhalo
Post by staknhalo » Sat Dec 11, 2021 11:24 pm
correct
Normal behavior, per DV spec it is tunneled over/through 8bit signal
jkatchy2
Post by jkatchy2 » Sat Dec 11, 2021 11:29 pm
Spec wise looks similar to Ugoos AM6 Plus apart from S922X-H vs S922X-J , beelink gt king pro seems to have two ESS HIFI decoding chips for sound . Wonder the dolby vision files support . Though it mentioned as it supports DV.
stn17
Post by stn17 » Tue Dec 14, 2021 5:34 pm
Can any of these new Ugoos versions handle TV-led FEL? Buying a proper sound system for my C9 and kinda want to get advantage of TrueHD/Atmos, which is impossible in mp4.
Epedemic
Post by Epedemic » Fri Dec 17, 2021 10:09 am
Let me get something straight: Can the X700 properly play FEL DV in .ts or .m2ts format made by tsmuxer using the bl & el hevc files made by yousopee's beta tool?
I've been doing bluray folder structure from tsmuxer and renaming to AVCHD folder every damn time, so .ts/.m2ts would be much smoother :D
Post by RESET_9999 » Fri Dec 17, 2021 8:06 pm
Yes, most of them play fine but for an unknown reason, some don't work.
Epedemic
Post by Epedemic » Sat Dec 18, 2021 5:46 am
Amazing, thanks for clarifying.
One more question: Any advantage to using .m2ts over .ts (or the other way around)?
