charnathan
Post
by charnathan » Wed Sep 15, 2021 10:17 pm
Bluntman wrote: Wed Sep 15, 2021 5:34 am
I respect and appreciate your advice, but I have never had to go to such lengths. It's funny I finished the LENGTHY backup using the other program. All I did was cycle the tray again for the upteenth time. Fired up MakeMKV and got a find rip now. Very happy even if it took a few goes.
i think it has more to do with the fact that this is a triple layer disc.
triple layer disc's take longer to be read by the drive, and longer to back-up/remux since it has to break through that third layer.
it took me a few time's. before windows would even open the disc folder. but opening the drive and reinserting the disc usually solved it for this and other 3 layer discs (Scott Pilgrim, Transformers The Last Knight, etc)
Ikisaru
Post
by Ikisaru » Tue Sep 21, 2021 3:36 pm
Is anyone else still having trouble getting these discs to rip? I was able to rip disc 1 but disc 2 keeps failing to open.
sssaturn
Post
by sssaturn » Tue Sep 21, 2021 7:12 pm
I’m still having trouble. Can’t complete a rip of the main feature or make an iso from disc 1. Haven’t tried disc 2 yet.
Not sure if it’s just the disc or my setup. I have MakeMKV v1.15.3 and a flashed LG WH16NS60
sssaturn
Post
by sssaturn » Wed Sep 29, 2021 1:01 am
Rip
eng050599
Post
by eng050599 » Mon Oct 04, 2021 1:04 am
I had issues ripping disc one of the Canadian release on two separate units. MakeMKV would indicate that it was reading the edge of the disc, and things would slow to a crawl before read errors would occur, and the rip fail.
After ripping the disc as an ISO using AnyDVD (copy protection removed), I was able to get MakeMKV to process the title without issue.
Disc 2 worked without issue from both retail units.
sssaturn
Post
by sssaturn » Tue Oct 19, 2021 10:48 pm
Which version of AnyDVD did you use?
Spearfish25
Post
by Spearfish25 » Fri Dec 17, 2021 3:33 am
Can’t get my disc one to rip. Haven’t tried two yet.
Post
by Billycar11 » Fri Dec 17, 2021 3:36 am
Spearfish25 wrote: Fri Dec 17, 2021 3:33 am
what error do you get volume key unknow or something else?
Spearfish25
Post
by Spearfish25 » Fri Dec 17, 2021 6:54 pm
Billycar11 wrote: Fri Dec 17, 2021 3:36 am
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00069.m2ts' at offset '2565341184'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '2565341184'
Error 'Posix error - Device not configured' occurred while reading '/dev/rdisk2' at offset '2565341184'
Post
by dcoke22 » Fri Dec 17, 2021 9:55 pm
Spearfish25 wrote: Fri Dec 17, 2021 6:54 pm
Is your drive connected via USB? Is it also powered by USB? If so, are both plugs plugged into a powered hub or directly into your computer? You might be running out of power during the rip.
Spearfish25
Post
by Spearfish25 » Sat Dec 18, 2021 12:53 am
dcoke22 wrote: Fri Dec 17, 2021 9:55 pm
The drive is in an external OWC mercury pro enclosure connected to my macbook pro by USB and powered by a separate power adapter. I was able to rip Disc 2 no problem. No issues with any other discs either. Just JL Disc 1. Fails every time.
Post
by Billycar11 » Sat Dec 18, 2021 1:20 am
Spearfish25 wrote: Sat Dec 18, 2021 12:53 am
Clean the disc
Replace the disc
If most other discs are fine you probably just got a defective disc.
Spearfish25
Post
by Spearfish25 » Sat Dec 18, 2021 1:31 am
Billycar11 wrote: Sat Dec 18, 2021 1:20 am
Clean the disc
Replace the disc
Yeah, i'll have to see what Best Buy will do. Had this sitting a while since I bought it. May be SOL.
Spearfish25
Post
by Spearfish25 » Mon Dec 20, 2021 4:41 pm
Spearfish25 wrote: Sat Dec 18, 2021 1:31 am
Clean the disc
Replace the disc
My disc was bad. New one had no issues.
