Downton Abby Season 6
Galas
Re: Downton Abby Season 6
#16 Post by Galas » Thu Apr 15, 2021 3:28 pm
Thank you so much for your hard work. I didn't want to sit and figure it out myself)
russellbateman
#17 Post by russellbateman » Fri Dec 17, 2021 3:39 pm
Thanks for this, I wish I had seen it when originally posted. If anyone is listening to this very late reply, I need to learn
a) how to use this information (MakeMKV, for sure, but then HandBrake?)
b) how to compile the same information for other series (Poldark, Endeavour and All Creatures Great and Small).
Any help would be appreciated. Meanwhile, I will keep looking.
#18 Post by dcoke22 » Fri Dec 17, 2021 6:35 pm
russellbateman wrote: Fri Dec 17, 2021 3:39 pm a) how to use this information (MakeMKV, for sure, but then HandBrake?)
Can you be more specific here?
russellbateman wrote: Fri Dec 17, 2021 3:39 pm b) how to compile the same information for other series (Poldark, Endeavour and All Creatures Great and Small).
What is the correct play list [insert title here]? Is a place to start.
Here's a thread about Endeavour: viewtopic.php?f=8&t=17643
A Better Way To Find The Correct Playlist/Segment Map <--- That thread is a bit long, but it has lots of discussion about different ways to figure out which playlist is the right one.
