SomeRandomUser1993
Re: Ultimate UHD Drives Flashing Guide Updated 2021
I bought today an Archgon MD-8107S-U3 with the LG BU40N(S) is this particular Model flashable and what does the (S) mean? Slim?
Any help/Information appreciated. (Just want to be sure..)
Regards
Regards
Post your makemkv drive info sectionSomeRandomUser1993 wrote: Tue Dec 14, 2021 3:33 am Hello,
Regards
SomeRandomUser1993
Sorry for the late reply.Billycar11 wrote: Tue Dec 14, 2021 1:18 pmPost your makemkv drive info sectionSomeRandomUser1993 wrote: Tue Dec 14, 2021 3:33 am Hello,
Regards
Here it is:
OS device name: I:
Product: BD-RE BU40N
Revision: 1.02
Serial number: MO7L91G2232
Bus encryption flags: 1F
Yeah you can flash that to read UHDSomeRandomUser1993 wrote: Thu Dec 16, 2021 1:10 pm Sorry for the late reply.
Here it is:
Drive Information OS device name: I: Manufacturer: HL-DT-ST Product: BD-RE BU40N Revision: 1.02 Serial number: MO7L91G2232 Firmware date: 2120-12-01 17:16 Bus encryption flags: 1F LibreDrive Information Status: Possible, not yet enabled Drive platform: MT1959 No disc inserted
MKV.User.Dave
Both versions...MartyMcNuts wrote: Mon Dec 13, 2021 7:27 amWhich version of SDFtool flasher??MKV.User.Dave wrote: Mon Dec 13, 2021 2:03 am Help?
The SDFtool fails to run on win10x64 machine...
Current profile: DVD-ROM
Product: BD-RE WH14NS40
Revision: 1.04
Serial number: KLZJ5F95330
Firmware date: 2119-01-04 13:51
Highest AACS version: 12
Harware support: Yes
Firmware support: No
Firmware version: 1.04
Hey guys,
just registered cause i'm a little lost which firmware i need to use on my HL-DT-ST BD-RE BH16NS55 drive thats already installed.
MakeMKV shows the following informations:
i already downloaded the newest version of the SDFtool Flasher and the current mk firmware pack. Can i just use the SDFtool and which firmware to i need to flash from the mk firmware pack to be able to play and rip 4k uhd blu rays ? I still want to be able to rip normal 1080p blu rays as well if thats possible.
greetings and thanks for the help
OS device name: E:
Product: BD-RE BH16NS55
Revision: 1.03
Serial number: <REDACTED
Firmware date: 2117-11-20 17:04
Highest AACS version: 66
Firmware version: 1.03
Unrestricted read speed: Possible (with patched firmware)greetings and thanks for the help
Yes you can still rip normal blurays.dsafad10 wrote: Thu Dec 16, 2021 3:00 pm Hey guys,
i already downloaded the newest version of the SDFtool Flasher and the current mk firmware pack. Can i just use the SDFtool and which firmware to i need to flash from the mk firmware pack to be able to play and rip 4k uhd blu rays ? I still want to be able to rip normal 1080p blu rays as well if thats possible.Code: Select all
Drive Information OS device name: E: Manufacturer: HL-DT-ST Product: BD-RE BH16NS55 Revision: 1.03 Serial number: <REDACTED Firmware date: 2117-11-20 17:04 Bus encryption flags: 17 Highest AACS version: 66 LibreDrive Information Status: Possible (with patched firmware) Drive platform: MT1959 Harware support: Yes Firmware support: No Firmware type: Original (patched version available) Firmware version: 1.03 DVD all regions: Possible (with patched firmware) BD raw data read: Possible (with patched firmware) BD raw metadata read: Possible (with patched firmware) Unrestricted read speed: Possible (with patched firmware)
greetings and thanks for the help![]()
Read the fist page the recommend firmware for your drive is WH16NS60 1.02mk it's in the all you need firmware pack
Thanks for the help! the process was very smooth and i'm able to watch and rip 4k uhd bds Sadly the performance is not like the normal bd rip buts its fine!Billycar11 wrote: Thu Dec 16, 2021 4:39 pmYes you can still rip normal blurays.dsafad10 wrote: Thu Dec 16, 2021 3:00 pm Hey guys,
thanks again!
Is MakeMKV installed in the default directory?MKV.User.Dave wrote: Thu Dec 16, 2021 2:22 pmBoth versions...
Is MakeMKV version 1.15.2 or above?
Have you tried running the flasher as Admin?
MKV.User.Dave
MartyMcNuts wrote: Thu Dec 16, 2021 9:51 pmIs MakeMKV installed in the default directory?
"C:\Program Files (x86)\MakeMKV\makemkv.exe"Is MakeMKV installed in the default directory?
MakeMKV v1.16.5 win(x64-release)Is MakeMKV version 1.15.2 or above?
AbsolutelyHave you tried running the flasher as Admin?
Additional info:
So? Install .NET and retry.
Hey all,
Just purchased a BP50NB40, and started the UHD flashing process.
I first flashed with the MK firmware using the SDF Flash tool (from the "The all you need firmware pack", and the following is what I've got:
Looks good.
I then attempted to flash the BP60NB10 firmware. SDFTool gives me the following warning, but then proceeds to flash "OK". However, when opening MakeMKV, there's no change to the firmware - hence no UHD for me.
Have I missed something?
OS device name: E:
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: SIK01L99G0500
Unrestricted read speedI then attempted to flash the BP60NB10 firmware. SDFTool gives me the following warning, but then proceeds to flash "OK". However, when opening MakeMKV, there's no change to the firmware - hence no UHD for me.
MKV.User.Dave
Ummm, it is installed.
Ugh! Looked at the box - and it has NB52 for it's SVC code. But I looks like I was able to flash an MK firmware onto it ...lordvader wrote: Fri Dec 17, 2021 4:48 am Hey all,
Looks good.Code: Select all
Drive Information OS device name: E: Manufacturer: HL-DT-ST Product: BD-RE BP50NB40 Revision: 1.03 Serial number: SIK01L99G0500 Firmware date: 2120-05-07 09:17 Bus encryption flags: 17 Highest AACS version: 12 LibreDrive Information Status: Enabled Drive platform: MT1959 Firmware type: Patched (microcode access re-enabled) Firmware version: 1.03 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed
Weird
Not weird - great!
