Hi everyone.
I'm in the process of building a PC, and plan to use the AMD Ryzen 9 5950X for my CPU and the ASUS BW-16D1HT for my optical drive. Because I want to be able to run and play Ultra HD 4K Blu-Rays natively (not necessarily rip them...for now), I plan to cross-flash to the WH16NS60 DE 1.00 firmware to fix the sleep bug. Will this work? I ask because reviewers were complaining that the LG WH16NS60's UHD capabilities only work for Intel CPUs (which is why I am getting the ASUS BW-16D1HT in the first place), and I'm worried that I will run into the same problem after crossflashing. I also tried searching the forums about this, but turned up with scant info.
Will Cross-flashing between ASUS and LG work with AMD Ryzen?
NapaVizer
Re: Will Cross-flashing between ASUS and LG work with AMD Ryzen?
It will work but just get the cheaper WH14NS40
What, precisely, do you mean by this? If you want to use official UHD software to play UHDs I think that requires both an official UHD drive and an Intel CPU that supports Intel Software Guard Extensions (Intel SGX).NapaVizer wrote: Wed Dec 15, 2021 7:03 pm … play Ultra HD 4K Blu-Rays natively (not necessarily rip them...for now) …
NapaVizer
I want to be able to load a UHD disc into the drive and play it like I would a DVD, CD, or regular Blu-Ray. While I might burn or rip the discs later on, I don't want to be forced to do a rip whenever I load a new UHD disc.dcoke22 wrote: Wed Dec 15, 2021 10:14 pmWhat, precisely, do you mean by this? If you want to use official UHD software to play UHDs I think that requires both an official UHD drive and an Intel CPU that supports Intel Software Guard Extensions (Intel SGX).NapaVizer wrote: Wed Dec 15, 2021 7:03 pm … play Ultra HD 4K Blu-Rays natively (not necessarily rip them...for now) …
I'm planning on using either VLC or MPC-HC to play UHD discs since people on the forum say you can do that, so I won't be using the official software.
In that case any decent CPU / GPU configuration (HEVC/h265 capable) will work just fine. With unofficial players such as VLC, MPC-HC etc you will need to use either MakeMKV or AnyDVD to decrypt the UHD disc "on-the-fly" when playing.NapaVizer wrote: Thu Dec 16, 2021 1:08 amI want to be able to load a UHD disc into the drive and play it like I would a DVD, CD, or regular Blu-Ray. While I might burn or rip the discs later on, I don't want to be forced to do a rip whenever I load a new UHD disc.dcoke22 wrote: Wed Dec 15, 2021 10:14 pmWhat, precisely, do you mean by this? If you want to use official UHD software to play UHDs I think that requires both an official UHD drive and an Intel CPU that supports Intel Software Guard Extensions (Intel SGX).NapaVizer wrote: Wed Dec 15, 2021 7:03 pm … play Ultra HD 4K Blu-Rays natively (not necessarily rip them...for now) …
the bigger question is what gpu do you have then needs to have h,265 decoding for uhdNapaVizer wrote: Thu Dec 16, 2021 1:08 am I want to be able to load a UHD disc into the drive and play it like I would a DVD, CD, or regular Blu-Ray. While I might burn or rip the discs later on, I don't want to be forced to do a rip whenever I load a new UHD disc.
Just so it's clear Intel dropped sgx on all future cpu starting with gen 11. As such powerdvd had also dropped support for uhd playback on windows 11, machines with the Intel drivers that remove sgx, or newer gen cpus without sgx. Basically, it's completely useless now without unprotected content.
I know that wasn't the op's intention for playing back... just wanted this info out there. RIP cyberlink. Lol
P.s. another awesome option for uhd playback with makemkv support is jriver MC. It's got its own video renderer now that is coming along nicely. Even has menu support. It's a paid software but I use it all the time.
wow i knew intel dropped sgx but did not know cyber link completely gave up on UHD what a joke it was a horrible implementation any way though very buggy.SamuriHL wrote: Thu Dec 16, 2021 4:10 am Just so it's clear Intel dropped sgx on all future cpu starting with gen 11. As such powerdvd had also dropped support for uhd playback on windows 11, machines with the Intel drivers that remove sgx, or newer gen cpus without sgx. Basically, it's completely useless now without unprotected content.
NapaVizer
Thank you all for your feedback! I just have a few more questions and comments.
Speaking of ASUS, I've been reading on this forum that crossflashing betwen it and LG it will pretty much permanently disable the ability to burn Blu-Ray discs. Does this always happen, or is it something that only happens to some people? I ask because again while I don't intend to be using it for burning or ripping discs, it's still nice to have that option if I ever decide to.
Does that mean a LG WH16NS60 player would work for AMD, since these players offer a work-around by decrypting on the fly? Or should I just go with either the WH14NS40 or ASUS BW-16D1HT and downgrade to WH16NS60 DE 1.00?MartyMcNuts wrote: Thu Dec 16, 2021 2:09 am
I'm using a RTX 3080 (shout out to my friend who managed to reserve me one!). According to this chart by NVIDIA it should support it. Is this true, or not really in practice?Billycar11 wrote: Thu Dec 16, 2021 3:21 am
Thanks! I will definitely look into this.SamuriHL wrote: Thu Dec 16, 2021 4:13 am P.s. another awesome option for uhd playback with makemkv support is jriver MC. It's got its own video renderer now that is coming along nicely. Even has menu support. It's a paid software but I use it all the time.
RTX3080, no problems. I'm using a RTX 2070 super myself.NapaVizer wrote: Thu Dec 16, 2021 6:46 pm Thank you all for your feedback! I just have a few more questions and comments.
Any of the drives you mention can decrypt on the fly using MakeMKV or AnyDVD. No point spending more for the NS60, just get the WH14NS40 and flash it to WH16NS60 firmware.
Yes, the ASUS has issues writing discs when cross-flashed to LG firmware. I wouldn't even bother with the ASUS drive. They are basically a rebadged LG anyway. Just stick with the cheaper WH14NS40.
Yeah I just found out the other day. But really at this point there's no need for an official player anyway.Billycar11 wrote:
