KEYDB.cfg not working with MakeMKV?
Hello everyone, I was able to get the key for Jaws UHD from the KEYDB.cfg file where I checked the hash and everything checks out. However, when I try to open the disc with MakeMKV, it still results in "The volume key is unknown for this disc". I put the KEYDB.cfg file in the MakeMKV directory and it is up to date. It looks like MakeMKV is not reading the KEYDB.cfg file at all. I also submitted the dump for it (6 days ago), but no luck with that which is why I tried the KEYDB.cfg file as it has the key. Any ideas? Thanks.
Re: KEYDB.cfg not working with MakeMKV?
Makemkv has its own keys do not put other keys in it.
You just have to wait untill it is added to makemkvs keys.
I get that, but the UHD FAQ says that the KEYDB.cfg file can be added which is why I thought that would work. It doesn't allow that anymore?
Not sure I have always done it though sdf/HK in the private data.tar folderMaxBane wrote: Tue Dec 14, 2021 7:06 pmI get that, but the UHD FAQ says that the KEYDB.cfg file can be added which is why I thought that would work. It doesn't allow that anymore?
Yea, all of my UHD blurays were ripped through MakeMKV's keys so far, but have 3 that still aren't supported (one of them 2 months). Just thought KEYDB.cfg file would help me with the few that can't be decrypted at the moment by MakeMKV.Billycar11 wrote: Tue Dec 14, 2021 7:15 pm Not sure I have always done it though sdf/HK in the private data.tar folder
EDIT: Two of them decrypted now, but not zombieland UHD
