SomeRandomUser1993
Re: Ultimate UHD Drives Flashing Guide Updated 2021
Post by SomeRandomUser1993 »
I bought today an Archgon MD-8107S-U3 with the LG BU40N(S) is this particular Model flashable and what does the (S) mean? Slim?
Any help/Information appreciated. (Just want to be sure..)
Regards
SomeRandomUser1993 wrote: Tue Dec 14, 2021 3:33 am Hello,
Regards
Post your makemkv drive info section
SomeRandomUser1993
Billycar11 wrote: Tue Dec 14, 2021 1:18 pm
Regards
Sorry for the late reply.
Here it is:
OS device name: I:
Product: BD-RE BU40N
Revision: 1.02
Serial number: MO7L91G2232
Bus encryption flags: 1F
SomeRandomUser1993 wrote: Thu Dec 16, 2021 1:10 pm Sorry for the late reply.
Here it is:
OS device name: I:
Revision: 1.02
Yeah you can flash that to read UHD
MKV.User.Dave
Post by MKV.User.Dave »
MartyMcNuts wrote: Mon Dec 13, 2021 7:27 am
MKV.User.Dave wrote: Mon Dec 13, 2021 2:03 am Help?
The SDFtool fails to run on win10x64 machine...
Current profile: DVD-ROM
Product: BD-RE WH14NS40
Revision: 1.04
Serial number: KLZJ5F95330
Firmware date: 2119-01-04 13:51
Highest AACS version: 12
Harware support: Yes
Firmware support: No
Firmware version: 1.04
Which version of SDFtool flasher??
Both versions...
dsafad10
Post by dsafad10 »
Hey guys,
just registered cause i'm a little lost which firmware i need to use on my HL-DT-ST BD-RE BH16NS55 drive thats already installed.
MakeMKV shows the following informations:
OS device name: E:
Product: BD-RE BH16NS55
Revision: 1.03
Serial number: <REDACTED
Firmware date: 2117-11-20 17:04
Highest AACS version: 66
Firmware version: 1.03
i already downloaded the newest version of the SDFtool Flasher and the current mk firmware pack. Can i just use the SDFtool and which firmware to i need to flash from the mk firmware pack to be able to play and rip 4k uhd blu rays ? I still want to be able to rip normal 1080p blu rays as well if thats possible.
greetings and thanks for the help :)
dsafad10 wrote: Thu Dec 16, 2021 3:00 pm Hey guys,
OS device name: E:
Revision: 1.03
Yes you can still rip normal blurays.
Read the fist page the recommend firmware for your drive is WH16NS60 1.02mk it's in the all you need firmware pack
dsafad10
Post by dsafad10 »
Billycar11 wrote: Thu Dec 16, 2021 4:39 pm
OS device name: E:
Revision: 1.03
Thanks for the help! the process was very smooth and i'm able to watch and rip 4k uhd bds Sadly the performance is not like the normal bd rip buts its fine!
thanks again!
MKV.User.Dave wrote: Thu Dec 16, 2021 2:22 pm
Both versions...
Is MakeMKV installed in the default directory?
Is MakeMKV version 1.15.2 or above?
Have you tried running the flasher as Admin?
MKV.User.Dave
MartyMcNuts wrote: Thu Dec 16, 2021 9:51 pm
Both versions...
"C:\Program Files (x86)\MakeMKV\makemkv.exe"
MakeMKV v1.16.5 win(x64-release)
Absolutely
Additional info:
So? Install .NET and retry.
lordvader
Post by lordvader »
Hey all,
Just purchased a BP50NB40, and started the UHD flashing process.
I first flashed with the MK firmware using the SDF Flash tool (from the "The all you need firmware pack", and the following is what I've got:
OS device name: E:
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: SIK01L99G0500
Unrestricted read speed
Looks good.
I then attempted to flash the BP60NB10 firmware. SDFTool gives me the following warning, but then proceeds to flash "OK". However, when opening MakeMKV, there's no change to the firmware - hence no UHD for me.
Screenshot 2021-12-17 153858.png (7.51 KiB) Viewed 17214 times
Have I missed something?
MKV.User.Dave
Coopervid wrote: Fri Dec 17, 2021 12:31 am So? Install .NET and retry.
Ummm, it is installed.
lordvader
Post by lordvader »
lordvader wrote: Fri Dec 17, 2021 4:48 am Hey all,
OS device name: E:
Revision: 1.03
Looks good.
Ugh! Looked at the box - and it has NB52 for it's SVC code. But I looks like I was able to flash an MK firmware onto it ...
Weird
Not weird - great!
