Have not mkv'ed 4K's in a while...
IHearIT
So tonight I decided to mkv my resent purchased 4K's for my Plex Server. I've mkv'ed many 4K's of mine in the past with my same setup with no problem. But when I started to do so my current version of MarkMKV (v1.5.x), it kept failing to open disc from the pre-scan. So I downloaded the newest version of MakeMKV, but still get the same error. None of the 4K DVDs will open from the pre-scan process. I decided to try a UHD that I successfully did in the past but it too comes up with the same pre-scan error. I kind of remember something about a KEYDB.cfg but can't remember and don't know if that has anything to do with it or not. Any help would be appreciated. Below is an example of the pre-scan:
- pre-scan2.JPG (92.29 KiB) Viewed 6327 times
Re: Have not mkv'ed 4K's in a while...
Have you enabled "Enable Internet access" in preferences so the hashed keys can be downloaded?IHearIT wrote: Tue Dec 14, 2021 12:11 am So tonight I decided to mkv my resent purchased 4K's for my Plex Server. I've mkv'ed many 4K's of mine in the past with my same setup with no problem. But when I started to do so my current version of MarkMKV (v1.5.x), it kept failing to open disc from the pre-scan. So I downloaded the newest version of MakeMKV, but still get the same error. None of the 4K DVDs will open from the pre-scan process. I decided to try a UHD that I successfully did in the past but it too comes up with the same pre-scan error. I kind of remember something about a KEYDB.cfg but can't remember and don't know if that has anything to do with it or not. Any help would be appreciated. Below is an example of the pre-scan:
IHearIT
Thanks for your response: Yes below is a screen shot. I also updated the frimware think that maybe an issue but still get the same message.
- Capture1.JPG (33.88 KiB) Viewed 6318 times
IHearIT
OK... I'm an idiot. So not doing this for so long... I just realized by looking at preferences (Thanks McNut's for pointing me to preferences!), my drive letters had changed and it was using a drive drive letter no longer assigned in my computer for the "MakeMKV data directory" Total error on my part. Sorry for wasting anyone's time.
exitguy
Same happened to me, so I setup a MakeMVKDataDirectory folder under Documents and use that as it will stay there for ever and a day.IHearIT wrote: Tue Dec 14, 2021 12:47 am OK... I'm an idiot. So not doing this for so long... I just realized by looking at preferences (Thanks McNut's for pointing me to preferences!), my drive letters had changed and it was using the MakeMKV data folder as a drive letter no longer assigned in my computer. Total error on my part. So for wasting anyone's time.
