Extract Subtitles UHD
Toby2k
Post by Toby2k » Wed Jul 07, 2021 6:48 pm
I am using the latest version of makemkv on my MAC. Is it possible to extract the subtitles from the UHD disc directly from makemkv into a separate file, for example idx, sub? If yes, how does it work?
BR
Tobi
jayper
Re: Extract Subtitles UHD
Post by jayper » Wed Jul 07, 2021 8:26 pm
No, you would need to create a MKV with MakeMKV first. Then use MKVToolNix to extract the subtitle files. If you need a GUI, then you can look into gMKVExtractGUI or MKVCleaver (not sure if either of these tools are available on Mac) to use in conjunction with MKVToolNix.
MKV.User.Dave
Post by MKV.User.Dave » Mon Dec 13, 2021 1:03 am
Well darn...
MakeMKV is already "processing" the subs, yes?
Is it too difficult to allow the writing to a separate file - the subs (chosen, before processing) - while MakeMKV is running?
Dave
