Dump firmware of HL-DT-ST DVDRWBD CA30N
schraube08
#1 Post by schraube08 » Sun Dec 12, 2021 8:45 pm
Hi! I'm not sure if this is the correct forum for my question - but it would be great if someone could help me.
I got a LG CA30N bluray drive and noticed that it has a riplock. As it's possible to remove the riplock from e.g. the CT30N drive (that is verly likely a relative of mine) with MediaCodeSpeedEdit I think it might also be possible for my drive.
My only problem is that I cannot find a firmware for my drive and all my attempts to dump the firmware of my drive are failing and so I hope someone else can give me a hint what to try next.
I already tried to dump with:
  • DevilsClaw
    SDF tool flasher
but failed with both.
Are there other tools I can try?
2021-12-12 08_50_11-MakeMKV BETA - Kopie.png (33.9 KiB) Viewed 8502 times
2021-12-12 21_34_39-2021-12-12 08_50_58-Administrator_ Eingabeaufforderung - Kopie.png ‎- Fotos.png
2021-12-12 21_34_39-2021-12-12 08_50_58-Administrator_ Eingabeaufforderung - Kopie.png ‎- Fotos.png (15.81 KiB) Viewed 8502 times
2021-12-12 08_52_47-SDFtool Flasher.png (9.33 KiB) Viewed 8502 times
schraube08
Re: Dump firmware of HL-DT-ST DVDRWBD CA30N
#2 Post by schraube08 » Sun Dec 12, 2021 8:48 pm
And here a ew pics of the drive itself
2021-12-12 17.40.22.jpg (1.56 MiB) Viewed 8501 times
2021-12-12 17.24.33.JPG (1.31 MiB) Viewed 8501 times
2021-12-12 17.19.23.JPG (1.59 MiB) Viewed 8501 times
schraube08
#3 Post by schraube08 » Sun Dec 12, 2021 8:50 pm
and the last ones:
2021-12-12 17.54.04.JPG (1.64 MiB) Viewed 8499 times
2021-12-12 17.41.23.JPG (1.96 MiB) Viewed 8499 times
#4 Post by Coopervid » Thu Dec 16, 2021 1:27 pm
I guess your attempt will not be successful. Devil's claw flasher only works with a Mediatek chip. Your pictures show a Panasonic chip. So the assumption is that this is a LG rebranded Matshita / Panasonic drive.
If I were you I would replace it with a BD / UHD drive that is dimensionally and electrically compatible. Be aware that some Laptop companies like Lenovo restrict the use of some drives and so there is a chance that it doesn't work.
Let me know if you have any other questions.
