Blu-Ray 'FIFA WM 2010 – Die Highlights' doesn't work
Helios61
Post by Helios61 » Thu Feb 24, 2011 5:54 pm
Hi Mod's and Dev's!
Unfortunately the Blu-Ray 'FIFA WM 2010 – Die Highlights' doesn't work here! MakeMKV_log.txt is attached!
Best regards
H
Re: Blu-Ray 'FIFA WM 2010 – Die Highlights' doesn't work
Post by mike admin » Fri Feb 25, 2011 9:37 am
Helios61 wrote: 002003:0000 Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf w?hrend des Auslesens von '/BDMV/STREAM/00006.m2ts' bei Offset '21044932608'
001003:0020 DEBUG: Code 2 at T^+5m05OP`M{'#=A:213136562
This indicates physically damaged disc.
