MakeMKV v1.6.5 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\tempadmin/MakeMKV_log.txt
DEBUG: Code 0 at MR+<l;,[G.bL/u?5&:213131042
DEBUG: Code 0 at Vs:iO}FTd)}l*rLQGg]]:29393953
The source file '/BDMV/STREAM/00295.m2ts' is corrupt or invalid at offset 969689088, attempting to work around
The source file '/BDMV/STREAM/00295.m2ts' is corrupt or invalid at offset 970260480, attempting to work around
The source file '/BDMV/STREAM/00295.m2ts' is corrupt or invalid at offset 970616832, attempting to work around
DEBUG: Code 0 at Vs:iO}FTd)}l*rLQGg]]:29393907
DEBUG: Code 0 at Vs:iO}FTd)}l*rLQGg]]:121262509
DEBUG: Code 0 at CQdHTn+?Xq-BeRMa"F,F:29394321
DEBUG: Code 475107 at CQdHTn+?Xq-BeRMa"F,F:29393309
DEBUG: Code 0 at TbxNL?L'!OrC\Vi%oQ9x4:29397449
Failed to save title 1 to file //oldnas/homeraid/movies/title01.mkv
0 titles saved, 1 failed
Pineapple Express
setarip_old
Re: Pineapple Express
Hi!
Sounds like a dirty or physically damaged disc.
Clean the disc and try again...
tickett
Haha- easy when you know how- thanks dude!
setarip_old
thanks dude!
As always, my pleasure ;>}
