Are some UHD discs unable to be decrypted? (Sent dumps long ago)
MaxBane
#1 Post by MaxBane » Thu Dec 09, 2021 6:38 pm
Hello everyone! Sent a dump in for Ford v Ferrari and Jaws UHD yesterday. I previously sent a dump in for Zombieland UHD almost two months ago twice, but that still also results in "The volume key is unknown for this disc - video can't be decrypted" error. Just wondering if some UHD blurays can't be decrypted? Thanks!
Re: Are some UHD discs unable to be decrypted? (Sent dumps long ago)
#2 Post by Woodstock » Thu Dec 09, 2021 8:06 pm
Does your log show any issues with collecting the hash key file?
#3 Post by dcoke22 » Thu Dec 09, 2021 8:51 pm
I wonder if your copy of Zombieland is the version that hasn't been decrypted?
viewtopic.php?p=94204#p94204
MaxBane
#4 Post by MaxBane » Thu Dec 09, 2021 9:02 pm
Woodstock wrote: Thu Dec 09, 2021 8:06 pm Does your log show any issues with collecting the hash key file?
It just gives the "video can't be decrypted" error. I should have the hash key file as I was able to rip other UHD discs I have and I have both keydb.cfg as well as the private data tar file that comes with makemkv (that's the hash key file, right?).
dcoke22 wrote: Thu Dec 09, 2021 8:51 pm I wonder if your copy of Zombieland is the version that hasn't been decrypted?
My dump ends with CC8B, so it seems to be a different version. I remember reading through that thread when I first tried to decrypt Zombieland back on October. What's funny is that the bluray copy came with both Zombieland 1 and 2 UHDs where Zombieland 2 decrypts perfectly :mrgreen:
Just in case, I added the dump files here for all three movies that can't be decrypted at the moment.
#5 Post by dcoke22 » Fri Dec 10, 2021 12:38 am
The Fixing Volume Key is Unknown post has info about messages in the log if key downloading is failing.
I got Jaws on UHD a bit more than a year ago and ripped it. Perhaps there's a new release with a new key.
MaxBane
#6 Post by MaxBane » Fri Dec 10, 2021 3:44 am
dcoke22 wrote: Fri Dec 10, 2021 12:38 am The Fixing Volume Key is Unknown post has info about messages in the log if key downloading is failing.
This is the log:
MakeMKV v1.16.5 win(x64-release) started
Using LibreDrive mode (v06.2 id=4FBA32AEC678)
Evaluation version, 29 day(s) out of 30 remaining
Saved AACS dump file as C:\Users\MaxBane/.MakeMKV/MKB20_v72_Jaws_5D9F.tgz
Looks like key downloads fine, so it most likely is a different version. I guess I need to wait for a decryption key for this version.
#7 Post by Woodstock » Fri Dec 10, 2021 1:34 pm
Actually, it's loaded the on-disk hash table for checking that the read completed properly.
There is no mention of trying to download the hash KEY file (logged as "HK"); do you have downloads disabled? Although, that would normally be logged.
MaxBane
#8 Post by MaxBane » Fri Dec 10, 2021 5:29 pm
Woodstock wrote: Fri Dec 10, 2021 1:34 pm There is no mention of trying to download the hash KEY file (logged as "HK"); do you have downloads disabled? Although, that would normally be logged.
I tried again and it doesn't mention anything about HK. The private data tar file is still from two days ago. Is the hash key file supposed to be downloaded every time a disc is being opened in makemkv? I just assumed it only downloaded a new hash key file if any new keys were added.
After enabling debug logs, I get this:
Debug logging enabled, log will be saved as C:\Users\MaxBane/MakeMKV_log.txt
Opening files on harddrive at F:/JAWS
DEBUG: Code 0 at S#u\au|JPy)q5}Kp:29396092
DEBUG: Code 0 at S#u\au|JPy)q5}Kp:29394850
Not sure if downloads are disabled, but if you mean that internet access needs to be enabled, it is.
MaxBane
#9 Post by MaxBane » Tue Dec 14, 2021 9:10 pm
Welp, looks like reinstalling the program did the trick or maybe the keys were added just now too. Jaws UHD and Ford v Ferrari UHD both decrypted now! :D
Going to try Zombieland UHD again as well.
EDIT: Zombieland is still a no go
